"All-in", all the time.
Old Apr 4, 2014 | 10:02 PM
Shark Racer's Avatar
Shark Racer
Originally Posted by micks69
That's the one I have
Take a look at MSD-8428 and/or talk to Lars and get a copy of his timing paper. A quicker curve will help out quite a bit with low end power.
Lars may recommend a different kit; I defer to his opinion.
Old Apr 5, 2014 | 11:58 AM
bluedawg's Avatar
bluedawg
I have a very similar situation. My Distributor will only add about 7 degrees of timing. To have 32 degrees (Vortec heads) all in I would have to have an initial of 25. It doesnt ping there but sounds kind of wacked to have mechanical (no vacuum) only add 7 degrees.
What springs are you running, I find that the light weight springs in the kits I've used add a lot of the mechanical at idle. You could test this by adding one or both medium or heavy springs and idle the vehicle. I'd bet you'd find a lot less advance or atleast that's what I've found. Good luck.
Old Apr 6, 2014 | 01:10 AM
vettezobsezzed's Avatar
vettezobsezzed
A picture is worth a thousand words. What about those little bushings over the pins the weight sits on. If they're missing, can allow it to have too much movement.
