"All-in", all the time.
Old Mar 11, 2014 | 10:35 AM
81_vette!'s Avatar
81_vette!
Default "All-in", all the time.
1977, manual 4-speed. Edlebrock carb, headers.
(Fairly new weights, springs, vacuum can, distributor, etc.) I previously used the Lars papers to set everything up just fine and all was well for 2+ years.
I get a solid 20-22 degrees vacuum from the carb with my gauge. No idle issues (other than being high, @ 950) and the car runs like a demon, no knocking or pinging or hesitation. Plugs look excellent.
Since my idle began to creep higher I thought it might be time to do some adjusting.
Now I seem unable to get any advance beyond idle.
Testing example, I can rotate the distributor and set the timing to 18, or even 36 at idle... and I get no centrifugal advance when going to 2800+ rpm. Plug the vacuum advance can up and get no advance there either. It's a set-it-and-forget-it proposition. "All-in", all the time.
I put in new weights and have tried several spring combinations.
So... my weights/springs are all-in at idle (or not in at all)... and my vacuum can no longer works?
Or, is this shade-tree mechanic missing something more obvious?
Old Mar 11, 2014 | 11:51 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Take the dist cap off and see if you can rotate the rotor a bit by hand. Watch the action of the weights,..are they 'expanding' and springing back to their idle position as they should?
Old Mar 11, 2014 | 11:52 AM
my 76 ray's Avatar
my 76 ray
The first thing I would do is take the dist cap off and try to turn the rotor by hand. It should turn the amount of the advance. If it doesn't turn then the advance is frozen.
Old Mar 11, 2014 | 01:20 PM
bluedawg's Avatar
bluedawg
If your using the light weight springs, they might be worn out, stretched and there for always advanced. Just a thought. Take one spring off and idle the car to see if it has advance there. If it dont, try replacing the springs to see if it falls back.
Old Mar 12, 2014 | 08:19 AM
81_vette!'s Avatar
81_vette!
Thanks for the information.
The rotor does indeed "snap back", and I cleaned the rotor/VAC plate up and tweaked everything I could.
Unfortunately, I can only get 6 degrees total advance from the distributor. I guess the shaft may be gummed up a bit?
So, I probably need to replace the entire distributor assembly.
I understand that I should expect about 20 degrees advance from a properly working distributor in general.
Old Mar 12, 2014 | 08:32 AM
RU7376vettes's Avatar
RU7376vettes
I recommend you start with basics like testing the vacuum canister. Do you have a hand held vacuum pump? If not then confirm that you do indeed have vacuum going to the canister, then unplug it while watching timing and plug it back in to see how much timing changes.
You said the weights and distributor mechanism snaps back, but does it have full range of motion? Before you change distributors, take yours out and throughly clean up the advance mechanism, also check for vertical play in the distributor shaft. If it is more than .010" then shim it to fix.
Your high idle is probably more a function of your carb adjustment than the timing. What have you done to address that issue?
Old Mar 12, 2014 | 09:12 AM
81_vette!'s Avatar
81_vette!
It snaps back, but I have no idea if it is a full range of motion. (The rotor will turn about an inch, and then snap back.)
How is the best way to test the range of motion? What should I expect to see?
The vacuum can is new and is an adjustable unit. It is definitely getting vacumm. You can hear a change in idle when you plug/unplug it, but it has no effect on the timing. Maybe the unit is bad, so I will test it.
As far as idle, I can adjust it at will and it responds nicely... but if I have to set my distributor so far advanced to get to 36 degrees all-in, I loose my 22 degrees vacuum at the carb when I adjust the idle back down to 750 rpm. I understand that I want the highest vaccum from the carb that I can get by adjusting the idle screws?
** Just to reiterate, I am not an advanced mechanic, so my process of doing this may seem amateurish, so bare with me ***
Old Mar 12, 2014 | 12:20 PM
bluedawg's Avatar
bluedawg
What springs are you using? You could either take one spring off and idle the engine, this would show you the total advance at idlle, or you you can note the timing as is, add the heavy thicker springs and renote the timing,I've had the springs wear out and stay advanced, mostly with the light weight copper colored springs.
Old Mar 12, 2014 | 12:31 PM
81_vette!'s Avatar
81_vette!
I am using a Mr. Gasket advance spring/weight kit.
Currently I am testing a medium (gold) and a (light) black in place.
I had two light (black) springs on it the past few years with good results.
I also tried a test run with two gold springs (medium) and had some hesitation on the road.
* The instructions that came with my springs seems different than what I read online as far as the colors of the springs and their stiffness... but you can easily tell which of the springs is stiffer.
Old Mar 12, 2014 | 12:37 PM
81_vette!'s Avatar
81_vette!
I will do that this afternoon. I will remove the springs and see what the idle is. Then put em' back in and see what the difference is.
Old Mar 12, 2014 | 01:05 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Did you confirm this with a timing light?
Old Mar 12, 2014 | 01:11 PM
81_vette!'s Avatar
81_vette!
Yes.
Old Mar 12, 2014 | 02:04 PM
bluedawg's Avatar
bluedawg
I will do that this afternoon. I will remove the spring and see what the idle is. Then put em' back in and see what the difference is.
You only need to remove one. See what the change is, if you dont see any change, install the heaviest spring and see if it drops timing.
Old Mar 12, 2014 | 02:13 PM
81_vette!'s Avatar
81_vette!
Will do.
Old Mar 12, 2014 | 07:13 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Yes.
Sort out your vacuum advance canister. Something is wrong here.
Old Mar 12, 2014 | 08:21 PM
diehrd's Avatar
diehrd
I think your misreading the timing light. I say this because
"idle increases when i hook up the vac can but timing does not change"
If not then the vac advance is causing a vac leak , it can not increase the idle speed with out doing one of those two things ,, Adv timing or cause a vac leak,
Old Mar 12, 2014 | 10:53 PM
bluedawg's Avatar
bluedawg
You think that the idle might increase because of the vacuum leak at that point?
To "All-in", all the time.
Old Apr 4, 2014 | 04:59 PM
micks69's Avatar
micks69
I have a very similar situation. My Distributor will only add about 7 degrees of timing. To have 32 degrees (Vortec heads) all in I would have to have an initial of 25. It doesnt ping there but sounds kind of wacked to have mechanical (no vacuum) only add 7 degrees.
Old Apr 4, 2014 | 05:08 PM
Shark Racer's Avatar
Shark Racer
There area number of kits out there that will help you get more mechanical advance out of your distributor. Changing the vac advance can will also change how much vacuum advance you get.
Many stock and even aftermarket distributors offer a very small mechanical advance limit. The basic Summit HEI distributor does not give a lot of mechanical advance.
Old Apr 4, 2014 | 09:28 PM
micks69's Avatar
micks69
That's the one I have
