Engine choices ..
The Motown LS block is also designed for the water flow characteristics and bolt pattern of the LS head. It is manufactured with a 9.240-inch deck height that matches production LS blocks, so off-the-shelf LS manifolds bolt right up. Headers designed for LS-style cylinder heads are required.
http://www.worldcastings.com/news_ar...iew.php?nak=69
Square bore (Holley style) LS intakes are available from World and Edelbrock to name two and correct fitment is already addressed by the articles. So the intake manifolds are there for your EZ-EFI.
Everything else from your current SBC will bolt right up.
THEN, there's the cool factor when you pop the hood ... onlookers exclaiming WOW an LS conversion ... Ohh WAIT !!!
THEN, you tell them that a 427 LS makes less power than your new LS Hybrid ... WOW more cool factor.
Finally, no denying that a 427 SBC would pop right in there with less hassle but where is the cool factor with that swap?
EDIT: 63mako did get his answer in before me ... probably while I was still pecking away on my keyboard
http://www.powerblocktv.com/episodes...allblock-build
I am past surprised no one on this forum has tried it yet ..
EDIT:http://www.powerblocktv.com/episodes...allblock-build Here is the link from above. Just watched it. Accessories is the only questions not answered
This Comp Cam press release explains it better than I can: http://www.theengineshop.com/product...f_file-177.pdf
Camshaft details/requirements also explained in this Super Chevy article: http://www.superchevy.com/technical/...der_heads.html
If you're assembling the Motown LS ( AKA Motown LS Hybrid) engine yourself then you would need to purchase 2 items from BMP to start: the un-machined block and the block kit. Here: http://www.worldcastings.com/product...ron-motown-ls/
Cam needs to have LS lobes because it's activating an LS valve train with LS geometry ... something you might expect if you're using LS heads. While an LS cam will slide into the block and work fine it won't have the distributor drive gear in the back and the fuel pump eccentric in the front like a standard SBC setup needs. HENCE, the need for a customized or "enhanced" LS cam where just 2 things have been added: the distributor gear and the mechanical fuel pump eccentric.
The cam with customized lobe profiles can be ordered by the builder from Comp Cams (CC) in any configuration they want OR order the Hybrid cam matching an existing LS street/race cam that CC stocks. diehrd posted above that Crane is making these LS Hybrid cams too.
Another article explaining the advantages of this Hybrid over an LS engine: http://www.enginelabs.com/features/e...iron-from-pbm/
Yet another great write-up & video on the Hybrid: http://www.lsxtv.com/tech-stories/en...d-ls-combined/
Yes, because the Hybrid uses the LS firing order (1-8-7-2-6-5-4-3) which is different from the traditional SBC (1-8-4-3-6-5-7-2) requiring the LS cam which has the 4-7 lobes swapped. With an LS style cam installed then simply moving the proper plug wires to the towers in sequence on the distributor cap will complete the firing order change.
