Headers to exhaust pipe problem
Old Mar 18, 2014 | 02:58 PM
riacreedon@gmail.com's Avatar
Default Headers to exhaust pipe problem
Finishing restoration of '70 conv, sb, 4spd. Engine mods brought hp to over 400, so installed McJacks headers which have 2 1/2" flange. New exhaust system is 2 1/2" also but has a 2" - 2 1/2" front pipe to connect to std 2" exhaust flange. Anybody sure whether I can substitute (for example) a '65 365hp exhaust pipe which is 2 1/2" at manifold flange?? Could really use help here.
Old Mar 19, 2014 | 01:26 PM
MelWff's Avatar
MelWff
whats wrong with a 70 454 pipe?
Old Mar 19, 2014 | 01:44 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
That probably wouldn't be bent correctly to fit without cutting and piecing. Patriot or McJacks may have an adapter pipe to hook up the factory exhaust. I know Hooker has then for connecting their long tube headers back to the factory system as I have that on my 77.
Old Mar 19, 2014 | 02:59 PM
I think the block size would be a factor! But thanks.
Old Mar 21, 2014 | 07:15 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Yes you can use the midyear connector pipe no problem.
Old Mar 22, 2014 | 06:55 PM
kanvasman's Avatar
kanvasman
I had an issue back in the day hooking a set of headers up to my stock - thru - the -crossmember exhaust on a C-2, After years of messing around, I finally took it to an exhaust shop and for a few bucks, he made me the correct pipes and I never had to mess with them again. Just a thought.
To Headers to exhaust pipe problem
