Steering column trim
Old Mar 18, 2014 | 03:01 PM
grumman41's Avatar
grumman41
Default Steering column trim
The plastic trim just below the steering column ignition assembly is broke beyond repair. I have the assembly notes but was wondering from someone who has been there, how far do I have to disassemble the steering column to replace this part? I am talking only about the plastic trim, not the aluminum "shift housing" under it.
If not for the mounting tabs for the column I could just slide it off of the bottom?
Kevin
Old Mar 18, 2014 | 03:09 PM
mrvette's Avatar
mrvette
I got into a similar jamb years ago.......I have a black column, and so I split the plastic, covered in vinyl, and slipped it in place, and secured with black tie wraps with tabs down to hide them....other than that, you have a late lamented broken *** over nothing.....
Old Mar 18, 2014 | 03:16 PM
BigAl5611's Avatar
BigAl5611
I don't know what year you have, but go here and you'll find all you need to know and more!
http://jimshea.corvettefaq.com/?cat=5
Old Mar 18, 2014 | 08:34 PM
grumman41's Avatar
grumman41
Thanks, Ive got his info just wanted to know how far I was going to have to disassemble to get the part replaced.
Kevin
Old Mar 18, 2014 | 08:53 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
If I remember right, you would have to have the special J tools to pull the shift tube and reinstall it.
Old Mar 19, 2014 | 11:30 AM
grumman41's Avatar
grumman41
Any takers?
To Steering column trim
