Diff. shops in Houston: Help
Old Jul 16, 2002 | 09:15 PM
Aaron-74's Avatar
Aaron-74
Default Diff. shops in Houston: Help
I need to swap the drive shaft yoke of the differential with another yoke so my drive shaft will fit my 3.70 geared differential. Does anyone know how to do this or know a shop and price. The neighborhood deeds are fixing to tow my car, i've got about 1 week to do this...HELP!!!!
Aaron.
[Modified by Aaron-74, 7:15 PM 7/16/2002]
Old Jul 17, 2002 | 12:54 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: Diff. shops in Houston: Help (Aaron-74)
You can do it your self.
If you have access to a 1/2" impact wrench it comes right off. If not, use a big pipe wrench to hold yoke and remove nut with regular ratchet and socket.
Replace the front seal while you're there and reinstall the new Yoke. Then just apply a little loctite to the threads ( a new nut is a good idea) and just tighten the nut back to correct torque specs. The only problem you will have is if you overtighten it and crush the crush sleeve between the pinion bearings anymore. This won't happen if you just use a torque wrench and tighten it down.
Someone handy with an impact can make the whole swap in about 3 minutes.
If you need help send me an I/M and I'll try to see if I can get by to help out.
You can also get "two sized" adapter u-joints at any parts store to adapt things together. Very common.
Jim
[Modified by 427Hotrod, 10:56 PM 7/16/2002]
Old Jul 17, 2002 | 01:00 AM
Aaron-74's Avatar
Aaron-74
Default Re: Diff. shops in Houston: Help (427Hotrod)
I'm not totally sure on the diff. Everyone that I have asked have said that I have to remove all the gearing and all that crap to swap them out....You seem like you've done it and I would really like your help since you seem to know what to do..I don't want to mess anything up. :cheers:
Old Jul 17, 2002 | 03:14 PM
Aaron-74's Avatar
Aaron-74
Does anyone want to help me..I really don't want to mess up my new 3.70 rear...
Old Jul 17, 2002 | 03:37 PM
77-4speed's Avatar
77-4speed
Aaron,
Call Fairfeld Auto Center in Cypress and ask for BJ. He has the number to a guy local that does diff repair on vettes all the time. His price is very reasonable. Tell BJ that Russ Fulks with the Corvette told you to call him.
Russ
Old Jul 17, 2002 | 08:55 PM
mountainmotor's Avatar
mountainmotor
Aaron,
Jim gave you the easy fix in his reply
Quote: "You can also get "two sized" adapter u-joints at any parts store to adapt things together. Very common."
Old Jul 17, 2002 | 09:10 PM
ram82fire's Avatar
ram82fire
Default Re: Diff. shops in Houston: Help (mountainmotor)
Aaron you just got good advice from jim and the mountain ,,, it is an easy swap.
Gman :crazy: :crazy: :crazy:
Old Jul 18, 2002 | 02:55 AM
427Hotrod's Avatar
427Hotrod
Default Re: Diff. shops in Houston: Help (ram82fire)
Aaron and I have traded numbers.... Geez that sounds like a date!
Anyway, we'll have him going by the weekend!
Jim
To Diff. shops in Houston: Help
