shoulder belts
Old Jul 16, 2002 | 09:15 PM
black71350's Avatar
black71350
7th Gear
Default shoulder belts
What's involved in installing shoulder belts in a 71 that never had them?
Also, do they feel fine or is the fit across the body annoying?
Old Jul 17, 2002 | 01:34 AM
riorata's Avatar
riorata
Default Re: shoulder belts (black71350)
'71 should have them. All cars were required to have shoulder belts as of 1 Jan 68. Bet someone just took them out and now the mounting holes are covered with carpet. Not difficult to put them in, but they are a little pricey to get replacements through the vendors. My $.02
From Bahrain
River Rat (Desert Rat for now) :flag
Old Jul 17, 2002 | 01:44 AM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: shoulder belts (riorata)
From Bahrain
Sorry for being off topic, BUT.
Just saw where you are, Rio.. Thanks for keeping the faith
Old Jul 17, 2002 | 04:23 AM
JB's Avatar
JB
St. Jude Contributor
Best bet is backseat belts from a '93 or newer camaro or firebird--I see 'em go for $20-$30 on ebay all the time and they are a direct bolt in.
JB
Old Jul 17, 2002 | 07:04 AM
Larry B.'s Avatar
Larry B.
I really like the original routing through the seat back. I get really annoyed with the ones that some cars have that go across you neck. I also like the original design with seprate shoulder belts. They are easy to staighten out compared to the one piece one.
Old Jul 17, 2002 | 10:58 AM
Juliet's Avatar
Juliet
Shoulder belts were an option in 1970 Convertibles. Coupes came stock with shoulder belts. According to the black book, shoulder belts were an option on all of the shark convertibles (through 1975). In 1970 the mounting plates are in all convertibles. To put in factory belts you'll need to modify the seat with the cutouts for the belt pass through. Or for a cheaper solution the seatbelts from a REAR late model camaro are a direct bolt in. The key is to make sure that the orientation of the inertial locking mechanism in your car is the same as the camaro. On my '70 the bolt for the seatbelt in the rear storage is on one of the wheel humps and the bolt goes straight down (just above the frame behind the wheel). I've posted photos of my setup several times to the C3 board - check the archives. ~Juliet
Old Jul 17, 2002 | 12:16 PM
madmaxgt's Avatar
madmaxgt
Default Re: shoulder belts (Juliet)
ROGER THAT! Mine came without them! 3 ways to tell are 1) rear holes plugged. 2) Seat trim has no provision for them. 3) visable halfmoon scratches on your lapbelt crome where the shoulder belt rides! MY 2 Cents! :)
To shoulder belts
