front air dam repair
Old Mar 21, 2014 | 09:28 AM
jim-81's Avatar
jim-81
Default front air dam repair
Just looking for some ideas on the best way to repair the front air dam (see pics). I ordered new rubber extensions but the air dam itself has a nice crack in the middle. I believe it's urethane. I've never done much bodywork and not sure what to use on urethane (fiberglass, bondo ? something else ?).
Jim
Old Mar 21, 2014 | 11:02 AM
929nitro's Avatar
929nitro
You may want to post in the Paint/Body section but I think only good option is to replace it.
Old Mar 21, 2014 | 11:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It's urethane. You may be able to repair it using bumper cover techniques.
Old Mar 21, 2014 | 01:10 PM
jim-81's Avatar
jim-81
yep, that's what I'm looking at - thanks
Old Mar 21, 2014 | 02:20 PM
hugie82's Avatar
hugie82
I bought the aftermarket fiberglass air dam and I wished I mailed it back! 1 hit and that sucker is junk! Fix yours, many good products on the market!
Old Mar 22, 2014 | 07:33 PM
DUB's Avatar
DUB
It can be repaired....but whatever you do....do not wipe it with a solvent of any type...which effects the urethane...just to let you know. Special cleaners which are water based is what should be used...even though I know many guys who do not give a crap and do it "they" way when they repair them. Just remember...if the top surface is not worth a crap for adhesion...how do you expect it to stick.
DUB
Old Mar 23, 2014 | 01:29 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Duct tape....
Old Mar 23, 2014 | 04:07 PM
mark79,80's Avatar
mark79,80
I have not repaired a urethane air dam but have successfully repaired
urethane bumpers using this SEM bumper repair product:
http://www.autobodytoolmart.com/sem-...2-p-16700.aspx
Product is also available in two larger tubes as well as in a dual cartridge
which requires a special applicator.
You will want to use some fiberglass reinforcing mesh on the back side
of the air dam. Mesh is the same product used between sheets of drywall.
First sand and clean the area. Spread some of the repair filler
across the cracked area and then press some of the mesh into the product.
After it dries spread some more filler over the mesh.
Sand and clean the front of the air dam. Apply the filler over the area
and sand when dry. If needed use a finishing filler over the area.
Evercoat makes one for flexible bumpers.
To front air dam repair
