q-jet problem modified 350
Old Mar 23, 2014 | 05:52 AM
badvette74's Avatar
badvette74
Default q-jet problem modified 350
hello,my q-Jet on my 74 makes Problems after this mods: dart shp 180 64cc,edelbrock Performer intake,headers,voodoo 262/268.
when i shift fast from first into second or second into third and so on...there is a flat spot for a second and then the power comes back,what can be the problem?
thanks for help and sorry for my bad english
greetings form Austria(Europe)
Franz
Old Mar 23, 2014 | 07:05 AM
haybabytwo's Avatar
haybabytwo
7th Gear
A Rochester Quad. has vacuum secondaries. Probably there is a drop in enough vacuum to hold them open. I would go to a mechanical carb. Also maybe play with the timing some. Just my ideas.
Old Mar 23, 2014 | 07:34 AM
cooper9811's Avatar
cooper9811
After my first engine swap to a 355 with a similar cam setup, I had a similar flat spot during acceleration (but was an automatic).
It wasn't the carb - it was a combination of timing and using vacuum advance source (which affects timing).
I needed to advance to somewhere around 13-17 degrees initial advance, 34-36 total advance, and use manifold vacuum for the timing advance, instead of the stock ported setup.
BTW, the QJet is actually a mechanical secondary carb, although it's still quite a bit different that you see on a double pumper, at least visually - but once correctly setup, it will react very quickly. A dead spot could also be due to the spring on the secondary flaps need adjustment - That could also affect how the secondary's react.
Lots of better QJet and timing experts on here then me - but if it ran OK with the previous setup, I would lean towards timing/vacuum advance setup needing tweaked first. I would try the timing setup described in the stickys above, and see what that does - it's easy and free - only takes time.
Old Mar 23, 2014 | 08:38 AM
badvette74's Avatar
badvette74
with the previous setup it ran perfect...so i will try another Timing Setup.thank you!
Old Mar 23, 2014 | 08:41 AM
7t9l82's Avatar
7t9l82
i think at least one thing is that secondary door. the quadrajet has mechanical secondary BUT that air door is vacuum operated. so you have to get both doors open so to speak before any air flows. you need to richen the carb up a bit, you have much better flowing heads and a bigger cam to boot. yours isn't far off what i have but i have a quick fuel 750 double pumper , to get the flat spot out of mine i have gone up 4 jet sizes and 2 squirter sizes and now its about right. if you want to keep that quadrajet id email Lars and get his thoughts on jetting etc.
Old Mar 23, 2014 | 09:28 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
My engine is similar to yours and I had Lars set up my carb recently. A good rebuild with good parts, jet size changes and applying the settings he knows from experience that work with my engine made a big difference. Once I got the timing set up correctly it was like I had a different engine. It was so much better in every way. Now it starts easily, idles MUCH better and at a lower RPM, runs MUCH smoother around town, and accelerates like it's rear end was on fire! SO much better all around!
Old Mar 23, 2014 | 09:30 AM
badvette74's Avatar
badvette74
i would like to keep the q-Jet if ist possible
Old Mar 23, 2014 | 10:15 AM
Street Rat's Avatar
Street Rat
If you want to stay with your current Q-jet I would get in touch with Lars @ v8fastcars@msn.com. He is the resident Q-jet guru so to speak.
Old Mar 23, 2014 | 10:22 AM
jnb5101's Avatar
jnb5101
Check the spring tension on the air-actuated secondary butterfly. The spring tension may be too loose and momentarily pass too much air when the rpm changes.
Old Mar 23, 2014 | 10:24 AM
Mike Ward's Avatar
Mike Ward
It takes two seconds to do this and it's free.
Old Mar 23, 2014 | 10:49 AM
badvette74's Avatar
badvette74
ok i will also try this.thank you guys!!!
Old Mar 23, 2014 | 11:26 AM
rene040269's Avatar
rene040269
OK, i read the advise to check things a lot, but how do you know what is the correct adjustment if you have nothing to compare to?
I know that experienced guys probably can feel immediately if the spring is too loose because they had felt it dozens/hundreds of times before but if you have little experience with carbs and no good carb to compare, what is "too loose" and what is "good"?
Thanks for explaining.
Old Mar 23, 2014 | 11:38 AM
Mike Ward's Avatar
Mike Ward
There's a simple adjustment procedure in every Qjet book. Going from memory, I think it's with the spring loosened, push the door open. Tighten the spring slowly until the door just closes, then add 1/4 turn more.
Not rocket surgery.
Old Mar 23, 2014 | 12:38 PM
scottyp99's Avatar
scottyp99
It's really just one of those things that you have to play around with. I'd start by tightening it up about a quarter turn and see what happens. Your flat spot may be a slight bog from the air valve opening to quickly, but then again, it may be from it not opening fast enough. With the modifications you have made, I suspect it may not be opening fast enough, but I'd still start by tightening it up a bit, (slowing down the opening rate) just to see how she reacts to it, and then go from there..
Scott
Old Mar 23, 2014 | 08:46 PM
gcusmano74's Avatar
gcusmano74
I would start the air valve preload at 1/2 turn. Then try 5/8. Most Qjet bogs are caused by a too loose setting of the air valve spring.
Or it could be a failed choke pull off canister, also allowing the air valve to flop open too quickly.
Old Mar 24, 2014 | 06:43 AM
badvette74's Avatar
badvette74
today i tried to tightening the spring,but there was no difference,then to loose it,also no difference...there is always this flat spot when i shift from first to second,second to third and so on....when i shift very slowly then there is no flat spot...
sorry again for my bad english
badvette74's Avatar
badvette74
To q-jet problem modified 350
Old Mar 24, 2014 | 08:38 AM
Mike Ward's Avatar
Mike Ward
Tighten some more.
Old Mar 24, 2014 | 09:28 AM
CaseyJones's Avatar
CaseyJones
Starting to sound like a bad accelerator pump.
Old Mar 24, 2014 | 10:02 AM
cooper9811's Avatar
cooper9811
Just curious - Have you tried reviewing and/or resetting the timing and vacuum advance yet?
