!975 Horn Help
Old Mar 23, 2014 | 02:57 PM
M-yellow01's Avatar
M-yellow01
Default !975 Horn Help
I'm trying to get the horns to work on my 75. I started at the horns themselves. Tested good with a car battery, after cleaning the ground area. I found the horn relay up high above the fuse box. I then jumped the red wire and green wire to the horns. They worked from there. I then tested continuity from the relay black wire to the steering column harness, the third blk wire from the right. That was good. Then from that same point on the harness, I tested continuity, to the horn spring loaded button on the hub assembly. Not good. My question is, where does the black horn ground wire end, in the steering column? Will I need to pull the hub, or can I just lower the steering column? There are no wires present at the horn eyelet. I tried for continuity at the lower contact assembly as well with no luck. I put in a new relay as well just to rule that out, I hope. Thanks, Tom
Old Mar 26, 2014 | 04:16 PM
M-yellow01's Avatar
M-yellow01
Well tomorrow I'll pull off the wheel hub and inspect the wires below the hub, around the blinker switch. I'm sure I'll need a wheel puller for that.
Old Mar 26, 2014 | 08:44 PM
DUB's Avatar
DUB
Turn signal switch. These is a copper plunger that is spring activated...and the spring can go bad and cause the plunger to fall down...thus not allowing it to touch the turn signal cam...which has the provision in it for your spring loaded contact that you are testing.
YES...you will also need a lock plate suppressor and more than likely the plastic insulator that goes over the "C" clip that you remove when you suppress the lock plate. It will more than likely shatter due to age.
You will need an Allen set screw to go into the center of you tele-shaft so it will stay put when you suppress the lock plate.
DUB
Old Mar 26, 2014 | 08:52 PM
C3Hawk's Avatar
C3Hawk
I am fixing the horn on my 75 as well! One of the issues is the plunger was flat. I'll let you know how it goes.
To !975 Horn Help
