1978 Corvette Heater - Temperature Control
Old Mar 24, 2014 | 01:49 PM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Default 1978 Corvette Heater - Temperature Control
So, silly question of the week here! How or what actually controls the temperature of the heat in the C3 heater, specifically, a 1978? I ask following the detachment of the Bowden cable from the control lever on my ’78, which prompted me to think what was at the other end of the cable! I know it goes to a small lever up in the heater box assembly, but what exactly does it do there? I also know that the valve in the heater hose in the engine bay is controlled, via vacuum, from the lever in the car, so what it the role of that valve?
I’m pleased to say I’ve re-located and more securely fixed the cable and the heater is now nice and warm or cool as I want it, but I’m just interested to know the “mechanics” which none of my books fully explain.
Old Mar 24, 2014 | 03:52 PM
MelWff's Avatar
MelWff
The valve turns the flow to the heater core on and off and the cable probably connnects to a door to vary the amount of air flowing through the heater core.
Old Mar 24, 2014 | 09:32 PM
Arkyvette's Avatar
Arkyvette
on my 82, I can see this flapper door through the opening for the blower motor resistor under the hood. When my cable broke I was able to use a long screwdriver to push the flapper towards the heat side to warm me up. That reminds me...i need to fix that cable..
Old Mar 25, 2014 | 05:28 AM
hunt4cleanair's Avatar
hunt4cleanair
The valve allows hot coolant to flow through the heater box. Blower switch blows air over the coils and hot air is blown into the heater box. Actuator valves located under the dash operate by vacuum from that Bowden switch, mix outside, cold air with the hot air from the heater box as it flows through the ductwork.
Your temp control switch on the console allows the driver to direct the hot/cold air mixture to different vents. For example, when defrost is selected, hot air goes to the windshield. Full heat selected, if I remember correctly, minimizes cold air and directs it to the windshield. When cabin heat is selected, actuator valves by the floorboard vents allows or limited cold air to mix with the ductwork hot air which comes through those side vents.
If you select A/C, the heater box actuator valve is closed so, theoretically, hot air is prohibited from entering the cabin and you just get cold air from the A/C condensor. But if that valve doesn't close...well than you have hot air that is getting in when you want just cold air and that becomes a common complaint with C3 owners.
Hope this helps
Old Mar 25, 2014 | 04:53 PM
my 76 ray's Avatar
my 76 ray
The valve shuts off the flow of coolant to the heater core when the Air Conditioning is on.
Old Mar 25, 2014 | 05:33 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
To expand a little.
When the TEMP control is specifically ON COLD.
The CABLE activates a vacuum SWITCH(above the heater box behind the glove box)that activates the vacuum VALVE in the heater hose.
Old Mar 25, 2014 | 05:48 PM
hugie82's Avatar
hugie82
Originally Posted by KapsSA
To expand a little.
Temp control only works the flapper door to direct the air. Either thru the heater core or AC Condenser.
The selector control, AC/ACmax,vent, heat, defrost
The heat position activates the heater hose valve with vac and sends the heat to the floor.
Old Mar 25, 2014 | 09:17 PM
KapsSA's Avatar
KapsSA
The temp cable also activates the vac switch/vac valve in the heater hose like described AND the door in the heater core housing.
Everything else is vacuum operated.
End of cable @ the door and vac switch....
Old Mar 27, 2014 | 06:45 AM
Stephen Irons
Hi Guys
Thanks for all the info, and the photos! As I say, I was just curious really, but this is all interesting stuff. I'm afraid I failed to take any photos of the fault or my repair! Hopefully nothing further will go wrong - it looks a whole lot of fun if anything vacuum related fails!
To 1978 Corvette Heater - Temperature Control
