Front Coilovers installation
Old Mar 27, 2014 | 12:08 PM
Dream Bikes's Avatar
Dream Bikes
Default Front Coilovers installation
Hi guys
I'm installing QA1 coilovers with new speed direct lower c-arms
After lower arms to frame installation, I’ve fixed QA1 shocks to the arms, but now I’m in troubles to correctly install springs and fixing shocks to the frame!
I know that this job is difficult also for stock springs/shocks but with QA1 coilovers it’s a real PITA because it’s not possibile to install the spring without removing the shock so there isn’t enough room to use a spring compressor!
When I try to lift the lower arms + shock/spring, I’m not able to set correctly the spring into the frame pocket and shock rod into the frame fixing hole...spring/shock are too much outward it seems that I’ve to bend the spring inward but many force is required to do that and I don’t have got any special tool to do that!
Is there any trick to do that? How can I safety install front suspension ?
Thanks for your help!
Old Mar 28, 2014 | 11:15 PM
Dream Bikes
no one?
Old Mar 29, 2014 | 12:03 AM
Ray Y's Avatar
Ray Y
Wow, those lower A-Arms are beautiful!
When I did my QA1s with tube A-Arms it was pretty simple to use a hydraulic floor jack on the arm to lift it into place properly so I'm not sure where you are running into issues. Your springs look to be a larger diameter than what I have with the kit from VanSteel and their QA1 package.
Old Mar 29, 2014 | 12:10 AM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
I'll send you a description and photo of what I use tomorrow morning. I'll need to take photo and get on the shop computer and I can't do that tonight.
Old Mar 29, 2014 | 12:28 AM
Patro46's Avatar
Patro46
I've been in a similar situation. I ended up having the springs banded (compressed and secured with a metal bands at a brake and spring company). This allowed me to get the coil overs in place, and connect the spindle before cutting the band releasing the spring. I only needed about 1.5 inches to get it together. Those springs look a little wider than I remember mine being. I'd call the company before getting too drastic. BTW, I absolutely LOVE those lower A-arms!
Old Mar 29, 2014 | 10:23 AM
Dream Bikes
Thank you so much I will really appreciate!
Old Mar 29, 2014 | 10:27 AM
Dream Bikes
Have you got a picture of these bands?
I've sent an email to Eric @ Speed Direct but I haven't received a reply yet!
Old Mar 29, 2014 | 11:00 AM
CWerner's Avatar
CWerner
My setup is van steel with QA1's. My springs OD is smaller and I too just used a hydraulic jack.
Old Mar 29, 2014 | 12:42 PM
ignatz's Avatar
ignatz
Hard to tell exactly from your pictures where the lower part of the coil over goes. I assume something sits on top of the lower A-arm, otherwise it is just the two shock mounting bolts that are holding up the car, isn't it?
Old Mar 29, 2014 | 12:56 PM
claysmoker's Avatar
claysmoker
I use a clamping arrangement made of 2 pieces of aluminum bar stock and 2 pieces of threaded rod. They sit behind the upper and lower ball joints on the inside and you can pull the a-arms together easily with them. I wrap them with towels to keep them from marking up the arms and that also keeps them from slipping. I've used them a lot and they work just dandy, even if they do appear a little Rube Goldberg. I tried the jack method and all it did was lift the car without compressing the spring enough.
Old Mar 30, 2014 | 06:43 PM
Dream Bikes
Man vs springs 2 - 0 !!!
Old Mar 31, 2014 | 02:24 AM
RBrid's Avatar
RBrid
Wouah, that's a gift to humanity D.B.! Looks awesome.
How did you get it to work after all?
Old Mar 31, 2014 | 07:39 AM
AAJC's Avatar
AAJC
WOW
That is one amazing looking setup.
Andrew
Old Mar 31, 2014 | 01:55 PM
Dream Bikes
Thanks guys, I will take some better pictures when I will finish the chassis (it's almost complete!)
Old Mar 31, 2014 | 06:59 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
This rookie wants to know how you moved the top of the shock inward?
(I had to use a 24"prybar on the tops of my stock coil springs )
Annnnnnnnnnnd......I'm jealous of that chassis!
Old Mar 31, 2014 | 10:35 PM
Dream Bikes
I used a block of wood and an hammer
I never thought it would worked!
But was simple, an hydraulic lift and "doctor" hammer works great together!
To Front Coilovers installation
