Body Off Checklist
Old Mar 28, 2014 | 07:33 PM
ctuinstra's Avatar
ctuinstra
Default Body Off Checklist
Any ever make a list of items to unplug, remove, etc before lifting the body? I'm sure many have removed the body and have had that one item they didn't know about or forgotten while lifting.
Old Mar 28, 2014 | 07:46 PM
John 65's Avatar
John 65
This should cover it. Lots of work but also lots of fun doing a body off. Enjoy the restoration.
http://www.corvette-restoration.com/..._Checklist.pdf
Old Mar 28, 2014 | 08:01 PM
ctuinstra's Avatar
ctuinstra
Thanks!
Old Mar 28, 2014 | 08:05 PM
soarguy77's Avatar
soarguy77
3rd Gear
Awsom checklist!! Thanks for sharing.
Old Mar 29, 2014 | 01:52 PM
GregS_72's Avatar
GregS_72
From: St Louis MO http://1972corvetterestomod.blogspot.com/
I'm in the middle of this list myself on my '72 big block car. Pretty good list so far, but did notice speedo cable not mentioned anywhere. Also, have plenty of PB blaster or the like on hand and start soon with getting access to body bolts so you can start soaking them. I'm taking lots of pics and organizing the pics by removal step/car part/etc. Label wires that were disconnected and organize/store every nut & bolt/etc in separate labeled bags/boxes. And for me getting access to the front bumper brackets was easier with the radiator shroud removed. I have #1-15 done so far as I work on it sporadically here and there.
Old Jan 7, 2017 | 07:50 AM
steersdad's Avatar
steersdad
I KNOW THIS IS AN OLD THREAD, BUT....It directs you to remove the steering column. I am rebuilding my 69, and have disconnected the rag joint. I've removed steering column's on C3's before, and to my recollection, no other part of the column is attached to the frame.
Any experiential guidance would be appreciated.
Old Jan 7, 2017 | 08:35 AM
Alan 71's Avatar
Alan 71
Hi sd,
You're right.
The rag joint is the connection between the steering column and the chassis.
Don't forget the interlock cable that's also right there at the steering column on 4 speed cars.
Regards,
Alan
Old Apr 7, 2017 | 01:41 AM
Youngvettehunter's Avatar
Youngvettehunter
Originally Posted by Alan 71
Hi sd,
You're right.
Regards,
Alan
what is the interlock cable? I've never heard of it...
Old Apr 7, 2017 | 03:11 AM
ganshert's Avatar
ganshert
I used the list linked above and found that it was missing the speedometer cable.
Old Apr 7, 2017 | 07:12 AM
Alan 71's Avatar
Alan 71
Hi,
The interlock cable is part of a theft deterrent system that was installed on all cars starting with the 69 model year on both 4-speed and automatic cars..
It's purpose was to prevent the transmission from being moved out of reverse, and prevented the steering wheel from being turned if the key is out of the ignition.
The cable runs from the steering column lever shown in the photo to the reverse shift lever on the transmission.
Regards,
Alan
To Body Off Checklist
