Q. Front Lamp Wire Colors
Old Mar 28, 2014 | 07:34 PM
Paul L's Avatar
Paul L
Default Q. Front Lamp Wire Colors
I am terrible at reading wiring diagrams. On the front lamp extension wiring is the "parking" wire brown and the "turn" wire blue or vice-versa? The black is of course ground. This is for a DRL system that I am re-doing, and dismantled after its module failed in 2012, and I can't remember which is which! I'll try again. The system worked well and I do not know why the module failed. Hopefully just a bad part.
Also, that black ground wire (driver's side) feeds into the front wiring harness. Would it hurt (T-section) to also feed it to the front frame? Someone suggested to me that perhaps an inadequate ground was the original problem.
Old Mar 28, 2014 | 08:30 PM
my 76 ray's Avatar
my 76 ray
The parking lights are brown and turn signals are dark blue according to the wiring diagram for my '76. I doubt that it changed.
Old Mar 28, 2014 | 08:38 PM
Paul L's Avatar
Paul L
That was my recollection as well. Thanks. I have some wiring, soldering, shrink-wrapping to do tomorrow in the basement. This is one job I can do without having the car out of storage and then just install things when it gets home (I'm trying for mid-April). But temps are above freezing now (just barely in the day) and things are looking up.
I have been on this earth many years and I don't recall a brutal winter like this.
Old Mar 29, 2014 | 06:22 PM
Paul L's Avatar
Paul L
Believe it or not, this does make sense. Bring on spring.
The DRLs run on the bright (turn signal) of the #1157 bulbs. And they are bright. When you actuate a turn signal the other side turns off and then both resume when the turn is completed. They de-activate when headlights are turned on. Pretty sophisticated little module. And in my view a safety feature for these low-profile cars in on-coming traffic.
Old Mar 29, 2014 | 07:08 PM
briankeery's Avatar
briankeery
I like it, good idea. Increased safety.....and it looks good.
Old Mar 29, 2014 | 07:40 PM
Paul L's Avatar
Paul L
If it works longer than the last module. Based on communications with colleagues I got a bad one. And I must admit it was replaced under warranty. Of course it will be over a year for me to add the 15-minute finishing touches. I had a really lazy 2013. The weather was discouraging.
To Q. Front Lamp Wire Colors
