1980 oil pump
Old Mar 30, 2014 | 09:38 AM
Chavlik's Avatar
Chavlik
Default 1980 oil pump
I think the oil pump is going out on my L48. Is it necessary to pull motor to get pan off or can I just lift it enough to remove the pan? Thanks
Old Mar 30, 2014 | 09:42 AM
boat196's Avatar
boat196
Why do you think the oil pump is going out?
Old Mar 30, 2014 | 09:54 AM
Chavlik's Avatar
Chavlik
Low oil pressure
Old Mar 30, 2014 | 10:00 AM
71454Chevelle's Avatar
71454Chevelle
Low oil pressure
Doubt its the oil pump. More likely bearings.
Old Mar 30, 2014 | 11:09 AM
qwank's Avatar
qwank
Old Mar 30, 2014 | 11:31 AM
Chavlik's Avatar
Chavlik
Confused, why would bearings lower oil pressure? Sounds like a crate in my future and I just finished a cam install. Sure hope not.
Old Mar 30, 2014 | 11:36 AM
71454Chevelle
Oil pressure is primarily determined by bearing clearance. Bearings wear, creates more clearance, oil pressure drops.
What is your oil pressure now?
Old Mar 30, 2014 | 11:55 AM
Chavlik's Avatar
Chavlik
According to factory gauge around 20. Planned on replacing sending unit first.
Old Mar 30, 2014 | 11:56 AM
Chavlik's Avatar
Chavlik
Cam and lifter failure last year. Maybe took out bearings....ugh
Old Mar 30, 2014 | 12:15 PM
Chavlik's Avatar
Chavlik
Old Mar 30, 2014 | 12:20 PM
REELAV8R's Avatar
REELAV8R
No you don't have to pull the motor but it is a bit of a hassle. Take exhaust out of the way.
Drop the steering arm that runs under it by removing the two retaining bolts on the passenger side that bolts it to the frame. If it's an auto the cooler lines can stay but are in the way a bit. Starter can stay on too.
Then you can take off the pan.
Low oil pressure could be worn bearings .
It could also be a stuck pressure relief valve on your current oil pump. On my OEM pump the pressure relief valve, spring was too short and was constantly letting oil through which I'm sure reduced the oil pressure to some degree.
It could be a worn oil pump, but not likely.
Try running thicker oil like Mobile 1 20W50 and see if your pressure comes up. That would be the easiest attempt at recovery.
Old Mar 30, 2014 | 12:22 PM
71454Chevelle
Most likely that is what happened.
hugie82's Avatar
hugie82
That will certainly cause problems but 20psi hot at idle isn't bad. Have you tried a heavier oil? Like a 20/50w or a straight 40w. It's a temporary fix but it will easily get you through the summer and then you can do the engine as a winter project! Maybe even collect some good parts over the summer and build a separate engine?
Old Mar 30, 2014 | 01:24 PM
REELAV8R's Avatar
REELAV8R
So you had a cam failure and didn't tear down the engine?
That's a gamble.
Could be you have small metal particles blocking the oil pump screen reducing your oil pressure. It's doing you a favor vs circulating those particles through the engine.
Old Mar 30, 2014 | 01:44 PM
hugie82's Avatar
hugie82
That's a gamble.
A wiped lob will rarely produce anything big enough to clog the screen but apron repair, if someone was sloppy and dropped pieces of intake gasket and other debris down into the oil pan. That will definitely cause issues! Most of the time you'll have great oil pressure idling in the driveway. Then when you start driving, the slushing of the oil in the pan will pick the gasket pieces up and then they will get sucked to the screen. Shut the car off and they float back down to the bottom.
Old Mar 30, 2014 | 05:42 PM
7T1vette's Avatar
7T1vette
Just for discussion, the standard Chevy V8 oil pump will only provide about 15 psi (10-20) at idle when warmed up. It should supply around 50 when at highway speeds, but idle pressure is significantly lower [by design] so that you don't waste fuel on building unnecessary oil pressure when the engine is not working hard. If your oil pressure is similar to what I described, you don't have an oil pump problem.
Old Mar 30, 2014 | 05:46 PM
Shark Racer's Avatar
Shark Racer
I've also seen bad oil filters (seen a few Frams do this) cause single digit oil pressure at warm idle. Switched to a newer one and it got into the mid 20s, warm.
Old Mar 30, 2014 | 06:00 PM
Chavlik's Avatar
Chavlik
Seems to stay around 20 and falls w throttle
Old Mar 30, 2014 | 08:13 PM
7T1vette's Avatar
7T1vette
If it falls off when you accelerate, either the filter by-pass is leaking off pressure or the pump is doing so. Change the filter and see what happens. If that fixes your problems, so be it. If it doesn't, repair/replace the pump. But, the standard GM pump will be fine for your car. Don't let "THE ZONE" talk you into the 'high-priced spread'.
To 1980 oil pump
