6t8 ragtop
Old Mar 30, 2014 | 11:48 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Default 6t8 ragtop
today I,m installing my new top and the steel calbes are broken that keep the top tight across the top of the window. any and all info on this subject will be appreciated. thanks Terry
Old Mar 30, 2014 | 12:29 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Order replacement cables.
Old Mar 31, 2014 | 04:14 AM
terrys6t8roadster
thanks, found them through Wilcox, then went throught the AIM to figure out which way they go [does the spring go forward? then realized there is an anchor end] and couldn't find the rag top brakedown. so, decided to slow down, odered parts, cleaned and am painting the frame works, letting the top side dry now.T
To 6t8 ragtop
