dropping the oil pan
Old Mar 31, 2014 | 01:45 AM
Belgian1979vette's Avatar
Belgian1979vette
Default dropping the oil pan
Is it possible to drop the oil pan on a C3 without loosening the steeringsystem ?
Old Mar 31, 2014 | 02:02 AM
7T1vette's Avatar
7T1vette
Yes. But, you would have to lift the engine. Not a good option.
All you need to do is to remove the two bolts on the idler arm (right frame). Then, the whole steering link group can lower enough to get the job done on the pan.
Old Mar 31, 2014 | 02:40 AM
akdale's Avatar
akdale
Concur with the idler arm drop. Just did this on mine.
Old Mar 31, 2014 | 03:21 AM
Belgian1979vette
Ok, I was fearing I needed to loosen the steering gear (again)
Old Mar 31, 2014 | 08:52 AM
jnb5101's Avatar
jnb5101
You also may have to raise the car on jacks (rather than having the car on the wheels) so the suspension hangs down. That will give you about 10 centimeters more downward movement of the steering mechanism.
Old Mar 31, 2014 | 04:20 PM
Belgian1979vette
Thanks for the suggestions guys !!
To dropping the oil pan
