Going to put some after market headers on my 78 L82 to get some more get up and go...
Anyone have any suggestions or what do you think of headers in general as opposed to keeping the manifold?
Thanks!
There is some benefit to adding headers to a basically stock engine but, unless you continue the process with a true dual exhaust system, the end result will be minimal. Headers will add some noise to the cabin, but not much and you will quickly get used to it. However, unless you plan to upgrade the complete system I'm not sure I would bother. Hooker makes a dual exhaust kit for headers that would be a great finish to your setup. As mufflers are not included you can reuse the originals or purchase something aftermarket. Summit and Advance Auto have that kit available for well under $200. Save more by using Advance coupon codes (google for them).
Headers increase the exhaust flow and add some beautiful noise. Get some Taylor spark plug wires that are rated for headers. I agree if you do the headers you should do the entire system to see the benefit.
If you have A/C, the heat from the headers could burn a hole in the evaporator housing.
Why do you think the surface of the headers is hotter than the surface of manifolds? The exhaust gases are what heats them and the exhaust temperature is the same whether its passing through a manifold or a header.
The header tubes are closer to the evaporator box than a manifold. At least in my case 1970 car. I posted a thread in the past asking if anyone else had a problem with headers causing damage to the evaporator box. Others had issues with headers distorting the evaporator box. Just my experience with headers on a A/C car.BKboiler do you have a A/C car with headers? If so, have the headers caused any damage?
Also if you get standard Steel headers they can eventually rot out and leak. I have painted full length headers and after half a year the paint came off and revealed bare metal. I Just sprayed them again with header paint and hopefully they won't rust
Boat196,
Were your headers ceramic coated? I am hoping that will help keep some of the heat out of the headers on my 69.
My car had A/C with headers for a while. I eventually removed all the A/C, including the evap box, but the box was not damaged. If your car has a big block engine, that might explain the heat damage from the headers, mine is a small block.
I ran headers on my daily driver '79 w A/C, no damage and not even an indication of excessive heat. Commuted in that car for 3 years, winter,summer, spring, and fall. Used the A/C every summer. My commute was 32 miles each way, mostly 4 lane interstate.
They are NOT really headers. They are called tubular exhaust manifolds and are essentially a shorter style header with individual runners. The problem is that the runners have VERY small diameter tubing-like 1-1.25 inches- which restricts overall exhaust flow but helps low end torque. My McJacks shorty headers have 1 5/8 inch runners and are terrific for mid-high rpm power. Personally on a stock like motor on the street I would not use Long TH with the heat, clearance-engine and road, noise, and very little performance difference versus Shorty's. just me.
I changed the tubular exhaust manifold like on the 81/82 C3's on my 94 mustang gt to BBK shorties and there was a BIG difference in performance with the 1 5/8 inch pipes versus the ford stock tubular exhaust manifold with 1-1.25 inch diameter runners. Don't bother with the 81/82 manifold and skip the long tube headers on a stock type engine-Shorties or block huggers-you will be happier in the end.
1. get lars papers for curving your distributor first
2. get your carburetor set up, again get lars paper
3. put on headers and dual exhaust.
4. wonder why the car didn't come this way to start with.
