Pros/ Cons of headers?
I changed the tubular exhaust manifold like on the 81/82 C3's on my 94 mustang gt to BBK shorties and there was a BIG difference in performance with the 1 5/8 inch pipes versus the ford stock tubular exhaust manifold with 1-1.25 inch diameter runners. Don't bother with the 81/82 manifold and skip the long tube headers on a stock type engine-Shorties or block huggers-you will be happier in the end.
Hope that helps!
You probably have the dual snorkel cold air intake air cleaner. This isn't a bad setup, I would keep it.
Pros: increased power and better exhaust note.
Cons: prone to leaking, if not maintained,
Not original. Some headers hang low.
Use a decent product and have them either ceramic coated or jet hot coated. The ball flange collector's are suppose to fight collector flange leaks, I've not personally used a set yet but my next set will have them. Look for a thicker flange that mates to head, off the top of my head, 1/4" & 3/8" are the flange sizes and the thicker flange is less prone to warpage. Currently I'm running hooker comps. Good fitment and don't hang to low, but they have a flat flange collector and 1/4" head flanges.
Good luck.
I noticed a real difference in the seat of the pants acceleration of the car. My guesstimate: 20-25hp was unleashed with the free flowing exhaust.
http://www.parts123.com/parts123/yb....ort~1~cadefibQ
The conventional wisdom says that you are better off with a nice, free-flowing 2 1/2" dual exhaust system using the stock manifolds, than with headers using the stock exhaust system, just FYI.
Scott
Scott
Con #1: You will be experiencing exhaust leaks from time to time, and generally will be replacing gaskets both at the engine and collector, from my experience, at least once a year give or take.
Con #2: The collectors hang down too low, causing ground clearance problems, especially an issue on Corvettes and other low riding cars. It's funny until it happens to you, going down the road 80 mph, hit a bump in the road, then all the sudden your car just got louder. You look in your rear view mirror about that same time and see metallic objects dancing in the street. You've just blown up your collectors.
Con #3: Too noisey (they add noise over exhaust manifolds) and have "tinny" sound. Personally I don't have an issue with this. But my neighbors do.
Pro #1: One of the best bang for your buck HP/TQ mod out there, not that difficult to install, but a lift is really nice to have. Can be done without one though.
Pro #2: Increase in torque everywhere, high, low, and midrange.
Pro #3: Increase in mpg. How many mods out there result in an increase in HP AND gas mileage?
I'd say as a rule of thumb if your car is a daily driver and you depend on it to get to work/school, I'd stay away from headers. If its a weekend warrior then ok. If any of the cons above you can't tolerate then I'd avoid them. The problem is when you go to modding an engine you almost have to have them. You won't get near the increase in power with a cam install without headers for example.
What I considered doing on my truck is just throw a whipple blower on the engine, keep the stock manifolds, and call it a day.
