electrical problem
Old Apr 1, 2014 | 10:58 AM
brandon_dow2's Avatar
brandon_dow2
1st Gear
Default electrical problem
Ok so I inherited a 1978 Vette that my dad brought new back in the day. The issue that I am having is that the windows will only go down if I manually push them down. Can somebody help me figure out what's wrong so I can fix it.
Old Apr 1, 2014 | 01:02 PM
Kevova's Avatar
Kevova
Posts lacks a little info, but I think you will need to remove a door trim panel. Do you hear motor operating either or both ways using switch? Check condition of regulator - rusty? and connectors both switch and motor - corrosion?
Old Apr 1, 2014 | 01:07 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
It sounds like a lubrication problem. If you can operate the switch and then push the window down the tracks probably need attention. A little WD40 or light lubricant sprayed down the tracks with the windows down might help.
Old Apr 1, 2014 | 01:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have power windows or manual windows?
To electrical problem
