How Much HP Will it make??
Get the RPM Airgap intake it makes good power.
Said Car below
I've done alot of reading here on the subject and choose a direction.
My goal is not a race engine/car but a reliable fun street motor/driver. I definitly wanted to build more horsepower than the wimpy L48. Here's where I'm going parts just arrived:
Scat 4340 stroker crank
5.7 rods (stock style w/press fit wrist pins)
Bore .030 over
Speed Pro Flat Top Hypereutectic Pistons
Hastings Moly Rings
Clevite main rod & cam bearings
Double roller timing set
#12-210-2 Comp cam:
1500 - 5500 RPM range
Lobe Sep -110
Duration - 268 / 268
Dur @ .050 - 218 / 218
Lobe lift - .302 / .302
Net Valve lift - .454 / .454
Comp Roller Rockers w/lock nuts 1.5:1 Ratio (same as stock)
Copm Hardened push rods
Elgin valve springs - good to .490 lift
New Flex plate
New balancer
Melling Hi Vol oil pump
Fel Pro gasket set
Rotating ***'y to be externally balanced
Long tube headers to true dual exhaust
I'm staying with stock heads for now (budget) but will give fresh valve job and port. Still haven't choosen an intake (suggestions welcome)
I love this forum and the depth of knowledge here so PLEASE tell me what you think good or bad.
Here's some pics:
Boring Block #1.
#1 - 7 Finished to 4.0280.
Set up to Finish Hone.
Dial bore gauge set to 4.0300. Each graduation = .0005''.
Cross hatch pattern for ring seat.
Home made ring filer .032 thick x 3'' dia cutoff wheel in bridgeport w/right angle attachment.
Filing Ring.
#8 piston w/ring compressor.
#8 going in.
Completed short block assembly fully torqued w double roller timing set. Drilled an orfice in the two oil galley plugs behind the cam gear for additional lube to timing chain.
we just did a C4 350 top-end build...
Edelbrock RPM heads, Edelbrock Pro-Flo XT EFI System, Edelbrock RPM cam 234° / 238 .539" / .548" ported and polished and port matched at 11:1 compression long tube headers, 2.5" duel exhaust...
395hp at the rear wheels....
The heads I chose are Flo-Tek's through Speedway Motors. I think the pair assembled were $746.00. 64cc chambers, 2.02 & 1.6 stainless swirl polish valves, bronze guides, top notch seals and valve travel good to .600'' lift.
I felt I was taking a chance due to not much out there about them. As I understand it the castings are poured in Austrailia but all machine and assembly work is done by the Tri State Cylinder Head Co. in Indiana.
The nomenclature packed with the heads recommends your choice of intake, intake gaskets, cam, as well as torque specs. I chose a Felpro #1206 gasket and ported the heads to match.
Here's some pics:
Dykem on head ports.
After positioning gasket and scribing guide lines.
Setup on mill with compound head and ball end tapered end mill.
I chose an angle that blends deep into the ports followed by hand polishing the runners.
Here's the result with 1206 gasket in position.
Same process to the new Edelbrock Performer Air Gap intake.
Here's some pics:
First the finished set up, top view.
Front view.
In the next pump view you'll see the lower left fitting (line in from tank), lower right fitting connected to new line to tee top side, and the new return line to connect to the chassis return to tank.
In the mock up stage I made a plug to insert into the tee past the port to carb. The plug has a .040 orfice in it to allow fuel to flow past the carb and back to tank when not needed (thanks Lars for the idea).
Here's the plug.
Inserted into tee.
The line assembly.
After running the engine up to temp you can feel how cool the return line is due to the fuel flowing thru it even though it is close to the head. Also as Lars stated (makes sense) my 8 GPM fuel pump output is more than enough to supply the carb even though a small amount of fuel is bypassing internally.
The spindle assembly.
All components.
Steam cleaned engine bay and undercarriage prior to detailing for engine drop.
Also new radiator, hoses, trans filter, and refirbed, blasted and painted drive shaft and half shafts and assembled with heavy duty u-joints.
Hopefully the Flo-Teks work out for the OP...keep us posted, madam.
