new wheel bearings or regrease
Old Apr 6, 2014 | 10:58 AM
teamo's Avatar
teamo
Default new wheel bearings or regrease
Car has been sitting for many years. All wheels rotate without any grinding sounds. Should I replace all of the wheel bearings just for good measure or will re-greasing them and reassembling everything be adequate?
Old Apr 6, 2014 | 11:47 AM
ddawson's Avatar
ddawson
The only way to know is to inspect them. If they are fine then repack the bearings.
Old Apr 6, 2014 | 11:49 AM
7T1vette's Avatar
7T1vette
You should pull them out, clean them with solvent, inspect them carefully, and either reuse them or replace them.
What you are looking for:
The bearing race should be smooth and free of pits, bumps, and should be relatively shiny. It should not have any rust/corrosion, chatter, or look "frosted". If the surface cleans up well and appears to be very smooth, it is probably fine to reuse it.
The bearing roller surface should look similar to the race...shiny and smooth. You should not see any significant rubbing/wear on the edges of the bearing cage which abut the rollers. Likewise, the cage surfaces at the ends of the rollers should not show damage. There may be some polishing/burnishing of these surfaces, but no inidications of heavy loading.
The cage should show no cracking at the corners of the cage slots.
P.S. If your existing bearings have been in place for many years and, when cleaned and inspected, appear to be in good condition, you would do best to thoroughly repack such bearings with a good quality synthetic bearing grease and reuse them. They have already proven themselves to be reliable...why gamble with 'new' ones (which are of 'unknown' quality)?
Old Apr 6, 2014 | 09:33 PM
hotrodnick's Avatar
hotrodnick
Old Apr 7, 2014 | 10:05 AM
my 76 ray's Avatar
my 76 ray
I agree with the above for the front wheel bearings but because of the difficulty/expense in taking the rear spindle off I think I would just run them until they need replaced.
Old Apr 7, 2014 | 11:59 AM
Marlin's Avatar
Marlin
Yea for front I would pull, inspect, clean, and regrease. The rear just replace due to the difficulty of just getting to them.
Old Apr 7, 2014 | 01:23 PM
7T1vette's Avatar
7T1vette
Agreed on the back bearings. They are 'trapped', so just dig into them IF you experience problems or need to work on the trailing arm assemblies for other reasons.
Old Apr 8, 2014 | 12:28 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I hate to say it, but...............If the grease in the original front bearings feels 'hard", looks dis-colored,or there isn't much grease in the bearing...there is a good chance that the rear wheel bearings need immediate attention also (I recently had the same situation with my project car....the rear wheel bearings would have failed within a couple months, costing me much more than a container of grease and a weekend of DIY bearing servicing).
Old Apr 8, 2014 | 01:17 AM
Patro46's Avatar
Patro46
Here are my thoughts, and I just completed mine today. After the royal PIA they are to do, as well as the expense of doing it in both parts and labor, I replaced the bearings and races along with new seals. It should last my lifetime, and then some. I also paid VERY CLOSE attention, keeping all parts on the left side, on the left side. Ect. for the right. This said, I'd recommend having a shim kit on hand, as NEITHER the left or right side bearing shims would work with the existing shims. 3 tries on one side and 4 on the other side and we had it perfect.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
To new wheel bearings or regrease
