need advice on engine mods
Intro:
Gentlemen, I need some advice on my engine.
I haven't been active a whole lot over here lately, I bought my 79 right when the recession hit, shortly after lost my job, was doing odd stuff, currently I got a long term job again and now it looks like I'll be getting divorce
, So I say F. the circumstances, time to do something in the garage!________________________________________ _______________
Info on engine mods:
Some background on the car. Car had some engine work done when i got it but I see absolutely no receipts to do with the rotating assembly so I assume the pistons and all are stock originals.
Here is some bills I found:
noisy gear drive
holley 4150 650cfm man choke 4b I dont see the choke pull lever anywhere please refer to photo if its represents this carb
edelbrock torker manifold
TCI converter pn241500 saturday night special
FEL PRO performance oil pan (looks like a regular pan with chrome finish)
rear main bearing fel pro 2900
melling m55hv high volume or moroso 22070 heavy duty oil pump - got receipts for both!
TCI flyweel int bal
fuel pres safety switch 5psi
The important stuff:
edelbrock single performance rpm 64cc
comp cams 12-210-2 high energy camshafts
comp cams 812-16 hydraulic lifters high energy
push rods hi-perf/mag
sharp 1001 ratio 1.5 c/8 stud
MSD ignition
A/F ratio monitor
Plus gaskets bolts and whatnot. I also found nitrous kit with 10 pounds of gas but I could not find anything nitrous related in the car
Drivetrain:
The trans is a th350 with BM shift improver kit, it looks like it was set for the heavy duty, not street strip for some reason, also spring in the accumulator was left in for smoother shift( per hand notes left by someone in the BM instructions) it has a cooler
Rear diff has higher gears, it also makes some humming noises at higher speeds and leaks, it does not leak from the cover and not from the pinion.(pinion seal is new)
Engine condition:
when I step hard on gas from a stop light sometimes there is a loud bang and engine stalls. Also engine developed oil leaks (pan, timing cover, valve covers) also that nice patina on my intake might be from carb leaking?
The plan:
I have a low 4 digit budget (aprox 3k) and I was considering how to get more HP/torque out of the engine while fixing leaks and stuff I am not a mechanic, I am also young and its my first experience with older cars. I am looking to do stuff by myself in my garage so I obviously wont do a stroker but I could throw a 142 roots blower on it (i understand its not as simple as it looks but a lot more doable than strokers and other stuff). Due to budget restrains I would like to keep mostly everything on the engine (heads etc)
The car is for hard street use, I do hard launches every time cops are not seen
, I accelerate fast but I do not drive at high speeds.So my engine runs out of steam pretty quick i shift at 5k, oil pressure would allow me to go for more but there is no point. As mentioned above I would love to throw a 142 blower on it, they go for about $2200/satin finish kit. And I would like to ask will the 142 work well with my engine? given the heads and cam what is my approximate compression ratio right now? (assuming stock pistons). Would I be able to modify my carb to work on top of the 142? I know the carb is small but I most likely will not go over 5k. I would prefer to modify this one due to costs and also would give me nice experience with some help from master david wizard carb book.
You are probably familar with the edelbrock heads (i know they are not great, 64cc chamber) here is some more info on the cam:
http://www.compcams.com/Company/CC/c...x?csid=73&sb=2
If you see any other areas that i could improve without something major like a head swap or strocker let me know, if the components combination I have is a bad fit please let me know. and if you have any other ideas in regards to getting more power in a garage with my budget please share!
hope I didn't bore anyone to death!
THanks in advance for any help,
Best Regards
Poppa
the way I see it - i need to start working on more advanced stuff to get more advanced experience, brake jobs and doing other maintenance stuff over and over again is not going to teach me a lot more, the reason why I'm thinking about the 142 is because it is relatively simple, single carb, not blow thru, and pretty much a bolt in package that leaves a lot of stuff not needed to be moded, (exhaust, cooling system etc). It appears to be 100 times simpler than turbo or centrifugal and it doesn't put as much stress on the crank as the big blowers so my stock bottom might be fine with it. I mean thats exactly what the mini blower was designed for - bolt on installation on stock engine. But first I need to find out if it even make sense to install on my current engine I mean is 110 lobe separation acceptable? will my current carb handle the small blower on a 350 if it will be boost referenced and rejeted with the rpm limited to 5000? These are engine builder questions and that's where this forum kicks in! experience of thousands in my living room! I appreciate any input on this!
Scott
Scott
Your driveability problems may be related to a number of things and you should evaluate and fix these, before you even start on a huge project like you're thinking. You're not happy with how it runs, but you want to throw expensive mods at it and to me, that sounds kind of crazy!
The 4150 is a great carb and yours looks reasonably fresh. Have you or someone experienced, made sure it was set up right? That makes a huge difference in how it runs. Idle, mixture, accelerator pump set up and this looks like a double pumper (correct me if I'm wrong), with Mechanical Secondaries. These carbs (I have one) will squirt huge amounts of fuel into the engine if they're not set up right. Smell the exhaust while it's idling. Does it smell really rich?
You get a loud bang and the engine stalls. That's not good and I'm willing to bet it's how the carb is set up. If it's set up wrong, you will have problems, big time! You should also evaluate the engine itself and take compression and leak-down testing on all cylinders. Check the distributor position and make sure you're absolutely on the number one plug at TDC.
Check the timing and also, make sure the vacuum advance works and that it's hooked up to the right port on the carb. Check all the vacumm lines and ports and make sure they're all good and tight. If the engine isn't happy, putting a blower on it, isn't going to make the driveability problems go away.
Just my .02
Good luck and welcome to the forum
PS your hood most likely won't fit with the blower. Keep that in mind
I have a stock bottom L48 with edelbrock performance RPM 64 cc heads and comp cams 12-210-2 Lobe separation 110 duration 268, lift 454
(http://www.compcams.com/Company/CC/c...x?csid=73&sb=2)
Would it be acceptable to mount a 142 single carb mini blower on this motor and keep it 93 octane rating and gain noticeable torque/hp?
I am assuming my current cr is about 9.4 (going from 76cc to 64cc). but dynamic cr is beyond me. I understand that the blower might have to be slightly under driven but that should free some parasitic blower loss...
What do you guys think?
A brand new Holley 670 Street Avenger will run you less than $400, but you also have to check your engine over carefully. Vacuum leaks will cost you a lot of driveability! Compression, leak down check, timing and distributor position at TDC. We don't see you attempting any of these things, but you want to buy a blower???
Scott
Get the 142 youll love it!! Awesome bang for the buck
second, future ex-wives have a habit of changing their minds as the process goes on, ( interpret as: sell to your best friend for 100.00, buy back after divorce is final) Nothing draws attention to you like new shiny parts..."if you have money for "THAT CAR " then you can have more money for ME! (sounds like experience???)
Three. save money for new engine build make it to your specs pull and install in one weekend. But like I said my two cents.
750 is recommended when building an engine with 142 in mind, that means more boost and lower CR
I have an engine with higher CR and heads that don't flow all that well
so if I want to keep it 93 friendly, I need lower boost so I used the equation to find out what cfm I need.
Aquarian thanks for the great advice!
PS. just checked, recommended cfm for utilizing the 142 capabilities is 700
