need advice on engine mods
2. put as much money as you can into a can and bury it somewhere.
3. dont do anything till the divorce is final!
thats my performance upgrade plan for your car.
So I will fix all the leaks and search for pro tune. Will keep you updated about the dyno numbers but it will take a couple of months (recovering from surgery and other daily tasks take priority)
I do have a 142 with 12 psi boost. It is a serious kick in the pants. however,....2k on one is not worth it given your engine. Wrong cam, carb needs mods, heads not so good and there is a host of other things. What gear ratio? Get it tuned properly and slap a set of 411's in it if available. You did say you want hard acceleration not high speed. You will be stressing u-joints though. Some solid spicers would be worthwhile.
Would be getting the car out of your name too. Have a family member you can sell it to for a buck?.....If you trust them that is
will fix leaks and get a pro tune... In a few years maybe I'll swap this engine into something lighter (volvo?) and start looking for new engine for my vette
Thanks Gents!
