1969 car. I have a 12 gauge, red with white stripe wire that I do not know where it goes. It has a flat blade connector on the end. It comes from the wiper limit switch and ends up very near the wiper motor. It must plug in somewhere close to the wiper motor because the wire is very short. Wiring diagram is not very clear as to the junction. Any help is appreciated!!!!
Probably different but my wiper motor has a single red wire coming out of the right side that goes to a connector that goes through the wiper door switch. That said, the switch has a 2 prong connector that leads in and out of the switch, sounds like your setup is different.
Thanks guys for the help, but I still can't find the connection. Of course the wiper motor does not run either. My wiper motor looks a little different from the one pictured. The wire I am referring to is coming from that round plug coming out of the limit switch and ends with that flat type connector on the end very near the wiper motor. It also looks like this connector is possibly the male side of a connection that may have a female type that goes somewhere (fuze block?) else. If so, that female plug and wire are missing. There is currently a 2 prong and a 3 prone plug and a ground wire hooked to the wiper motor/pump. Any other ideas?
There are separate 3 and 2 wire connectors to the motor and washer as well as that red wire and the ground.
That red wire should be the main power to the motor.
Wilcox has some video's on checking the wiper on the 69, perhaps they could help
M
Thanks Mooser. I will check out those videos. Since it seems like this red/w/white stripe wire is the main power wire, this is most like why the darn thing doesn't work!!!! Thanks again.
OK. Checked out the Wilcox info. Seems like there should be a red wire with white stripe coming out of the wiper motor somewhere. This would plug into the connection that I have coming from the limit switch. I will take off the wiper motor if that's what it takes to find the red power wire.
wiper motor is off. No red wire coming out anywhere from the motor nor is there any place to plug in the red wire I do have. Back to square one. I have power at the dash switch and at the 3 prong connector. Any ideas?
OK great pic!!! Mine definitely does not have that red wire coming out of the motor. So Dub u r correct. I do not have the correct motor. I will order one ASAP. Thank you everyone for their effort in helping me fix this problem!!! I owe u one!!!
