Help with Carb
Old Apr 15, 2014 | 01:17 AM
rlsterling3's Avatar
rlsterling3
Default Help with Carb
Hey all, I'm getting ready to install my new headers this weekend (hooker super comps) The car is a 1981, the AIR tubes have been cut and welded. I think the entire smog system has been removed, but I am not certain. When I install the new headers and exhaust I want to rebuild the carb. It's the original quadrajet. Because the SMOG system was removed or mostly removed am I going to have any issues with the carb? I'm new to this and I understand the 1981 had some sort of computer controlled carb. Can I just rebuild this with new jets and rods to meet the performance needs of the engine? Any help is greatly appreciated.
Old Apr 15, 2014 | 09:41 AM
7T1vette's Avatar
7T1vette
The '81 carb (if original to the car) is a one-year-only hybrid carb with an electric solenoid operated fuel metering device in it. The 1st year ECM managed the carb, distributor, O2 sensor and worked pretty well when in good condition.
Do you still have the CCC system components on your car (disregarding what was done to the emissions stuff)?
Old Apr 15, 2014 | 10:38 AM
rlsterling3
The computer is still in place behind the drivers seat. I'm not sure what all is supposed to be hooked up in the engine bay. I have found several plugs under the hood that aren't attached to anything. I'm assuming this was for the original smog equipment. The AIR tubes were cut and welded closed. How can I tell if the distributor is stock? I know the carb is. I decoded it and it is for the 81
Old Apr 15, 2014 | 12:33 PM
Shark Racer's Avatar
Shark Racer
A computer controlled distributor should not have a vacuum advance and will have an extra harness of wires going to it for the advance command and RPM output. A non-computer controlled distributor would only have a 12V wire and tach output wire, it is otherwise self contained.
Old Apr 17, 2014 | 08:26 PM
rlsterling3
I'm a bit confused. It appears that thus delco remy has a vacuum line coming off it but has several wires as well. Maybe I should post a picture. The carb has a vac line off the rear that has been sealed with a screw. Trying to see where this went as well...
Old Apr 17, 2014 | 08:56 PM
Shark Racer
Pictures?
A regular HEI dist will have 3 wire harnesses and they'll all be plugged into the same spot, a rectangular outcropping on the cap/coil. 2 1-wire(tach and 12v) plugs and 1 multi-wire plug. All 3 wirepacks connect to the distributor. There will also be a vac advance can.
A computer controlled dist will have the same wires as above, plus a second wire pack leading to the ECM.
The vac line you're talking about, if it's attached to the baseplate and rather small (3/16" I believe), is likely used for themac air (the flapper valves in the air cleaner snorkel).
Old Apr 17, 2014 | 09:19 PM
rlsterling3
As soon as I get home im going to take a few pictures and post them. I appreciate the help
To Help with Carb
