1968 327 Convertible
Well I am diving into the 68 and figuring out what has been changed and what needs corrected. It is NOM based on the distributor (no mechanical tach drive but is a points distributor) and intake manifold (too tall, air cleaner won't clear factory hood, which explains why it was in a box of spare parts instead of installed). It does have a Q-jet on it. The 327 has had some work done to it based on compression and idle, definitely had a cam upgrade. Engine doesn't want to even run at 4 degrees timing. Shifted timing to about 10 degrees and it smoothed out and ran.
So first question, and ideas on how to determine proper timing for an engine when you have no idea what cam swap was done? I went with the old 'sounds and runs right' timing. Drove it, no stutters, no knock, engine seemed quite happy. Revving little critter.
Next question: Anyone want a set of black SB headers with side pipes? New exhaust system, headers, intake manifold, and all gaskets/hardware are already on the way.
Next, brakes - Lip seals on front calipers are leaking. Best I have found is a complete O-ring kit for $50 per caliper at Corvette Central and a less complete kit from Eklers for $40/caliper. Is it worth it to switch to the O-ring pistons? The rebuild kit for the lip seal style is $15/caliper.
I suspect a common rant from me on this car will be the half done jobs by the previous owners. If there are 2 pieces of mounting hardware for a part, one was torqued down and the second is loose. Or at least that has been the theme so far. Start acting up? Add shims. still acting up? Add more. I removed all the shims and the starter is now working fine.
Any of you guys with experience going thru a 68 that has spent most of its life sitting parked, I would love to hear from you regarding your experiences. The end goal is a driver, not a show car, and not a track car. Ideally, I would like to have it straightened out and reliable before the Corvette Carvan in August. That trek sounded like a good excuse to put a few hundred miles on it.
Thanks and I look forward to hearing from you all.
2. Do you have stainless sleeved calipers?
Turn those headache-related problems into adventures....(I learned that fact after my second bottle of Tylenol!)
EDIT: OOOPS.....I just remembered that another Member posted the statement a few weeks ago
I just responded to a post you made earlier. I am about ready to get started on a brake problem that came this weekend. I will be the first to say I'm a little stupid here, and hate to admit I have no clue how to tell if my calipers have stainless sleeves. How do you tell.
Thanks for any help!
Larry ( stupid )
Exhaust arrives today, full system from Corvette Central; headers, duals, and Magna Flow mufflers. Looked at the MF systems and liked the X pipe setup, but the kit I ordered came w headers compared to the MF system that did not include them. I added new hangers, alternator braket and SS tips and ended up at the same price as the MF system that consisted of only the intermediate pipe to the tail pipe. Would love to have the X pipe, but $ talks and this gave me more parts for the money.
Hope to get at least the intake swapped this weekend, but Easter is interfering. If I am really lucky, the intake and exhaust will both get done.
Found another problem as well. Thought the starter intermittently grinding was a battery issue, so I replaced the 500cca with a new 750cca. Didn't fix it. SO time to pull the starter and hope the bendix is the issue, and not flywheel teeth. It is currently bolted direct, no shims.
Adding shims would drop the bendix relative to the flywheel thereby reducing the contact area on the teeth, correct? If it is not getting solid contact now, shimming should only make it worse, at least in my mind. Anyone have more experience with shimming the starter? Everything I have ever owned was the 'thru the bellhousing' type starter that didn't require shims, so this is new to me.
You mentioned SB headers and sidepipes; did you find a home for those yet? I may be interested if they are worth saving. Thanks, Brian
Now for the problems.
Mr Gasket dipstick tube sheared off flush with block. Ideas? Engine is still in the car.
Teeth on starter are worn. Worse yet, teeth on the flywheel are damaged. Looks like I was right, there should not have been shims.
Only way I know to get the flywheel out is drop tranny or pull engine. Garage isnt set up for either currently. Have to move 69 out to work on 68.
Another thanks on the suspension/idler arm tip for dropping the oil pan. Tried the easy out and could not get it to budge.
Although with the two combined, I am still debating pulling the engine. Not sure yet, switched gears to the 69 while I am debating what I want to do next on the 68.
Replaced rotors/pads on all 4 corners of the 69. Those rivets are a challenge, but not overly difficult to drill out. Then ground the remainder flush with the hub flange. As a precaution, want to replace all the coolant hoses on the 69 and possibly the vacuum line kit, then it will be interior and paint for that one.
There are three Vettes. Two that I am working on and one that is a driver.
1969 coupe 427/390 4spd, 46k miles, numbers matching car. Changes from original are the hurst shifter, Holly 800 spreadbore, power steering and A.I.R. were removed. Originally orange, currently Marlboro maroon. Hope to have it repainted to original this summer.
1968 convertible, currently has a 327, 4spd. 68k miles. I have yet to determine original engine for the car. Fairly confident that the current 327 is not original for this car. Stamping on right front of block has been painted over at least one and I cannot make out any stamping.
1974 coupe L48, 4 spd. PS, PB, Tilt/telescopic, leather. 42k miles. Original aside from a repaint (and a bad one at that!) by previous owner in 1998.
The 69 has belonged to my father since the 70's. The other two are mine.
Took lots of pics of the process, so if anyone is curious or likes looking at pictures, here you go. lol
