Tranny help!!
Old Apr 16, 2014 | 10:08 PM
kobra01's Avatar
kobra01
Default Tranny help!!
71 big block 4spd. Had new engine installed. At the same time had tranny removed and freshened up. New bearings, seals gaskets, shift forks basic kit. New centerforce dual friction clutch and pressure plate, throwout bearing and pilot bearing. Engine runs great. Clutch or tranny has a problem. Clutch in, put in 1st gear and take off. Shift to 2nd and kind of hard to get in gear and it grinds. 3rd gear same thing. Put it back in 1st gear and it doesn't want to go into 1st gear or any other gear (I think it may be in the last gear still) . Have to fight with it to try all gears and finally it will go back into a gear. I can put the clutch in and the car will stop without the engine dying so I think the clutch is working fairly well.
I know this is a pretty vague description of what's happening but does any one have an idea of what could be wrong?
Thanks in advance for any suggestions.
Old Apr 16, 2014 | 10:14 PM
keithl1967's Avatar
keithl1967
Have you adjusted the shifter linkage (is it a hurst, or stock shifter)?
Also, have you adjusted the clutch linkage for proper play in the pedal? It should have about an inch to an inch and a half of "free play" at the top of the pedal before the throwout bearing engages the pressure plate...
An improperly adjusted pedal linkage or shifter rods could cause the issues you are describing...
Also, after "freshening up" the tranny, what gear oil did you use?
Old Apr 16, 2014 | 10:15 PM
63split63's Avatar
63split63
Check the clutch pedal free play . You should have about half an inch free pedal travel .
Also check that the Z bar is not in backwards .
Bill
Old Apr 17, 2014 | 02:00 PM
kobra01's Avatar
kobra01
Keith|1967
Stock shifter
adjusted the linkage
adjusted the clutch
used 80W 90 GL5 non syn
63split63
will check on z bar. zerk fitting/plug towards front of car right?
Old Apr 17, 2014 | 02:09 PM
Sayfoo's Avatar
Sayfoo
After all the obvious, is your clutch fork installed on the throw out bearing correctly? There were some pictures posted recently here about this.
To Tranny help!!
