Always Something
Old Apr 17, 2014 | 01:11 PM
bugzbunny's Avatar
bugzbunny
Default Always Something
Good morning all, have another issue with vette. Has my mechanic install the new can and timing chain. Car runs great except when I want to get on it, it goes flat. Exchange the carb and same thing. So any idea's??
Has me and my mechanic stumped.
L-46 350-350 Power everything. Holley 770cfm ultra had a 750cfm on her before.
Old Apr 17, 2014 | 01:14 PM
Les's Avatar
Les
I'll run the risk of being Capt. Obvious. Have you checked, with the engine off, to make sure you're getting full throttle opening at the carb when the gas pedal is on the floor?
Old Apr 17, 2014 | 01:22 PM
bugzbunny's Avatar
bugzbunny
yes
Old Apr 17, 2014 | 02:54 PM
general69's Avatar
general69
secondaries opening too soon.
change the spring to a heavier spring so secondaries don't open as fast.
hollys generaly come with a lighter spring for midsize (heavier) cars
also make sure your secondary "shooter" nozzles are giving a good shot when you slam it wide open
Old Apr 17, 2014 | 05:06 PM
keithl1967's Avatar
keithl1967
what size air cleaner are you running? If you aren't feeding the motor enough air, it will flatten our quickly...
Old Apr 17, 2014 | 06:15 PM
diehrd's Avatar
diehrd
Describe flat ? It can mean different things to different people.
Check float levels , Check timing and make sure it is advancing.
To Always Something
