73 vette conv
Old Apr 17, 2014 | 08:54 PM
trippin's Avatar
trippin
Default 73 vette conv
just need to jack it up and figure out where to ck the speedo cable. Where is the best place to put floor jacks and the jack stand.
Old Apr 17, 2014 | 11:35 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Mirage2991 has a good pic of jackstand placement.........
Old Apr 18, 2014 | 12:23 AM
rogman16's Avatar
rogman16
If the car is together with engine in, I would move the front jack stands to in between the steering box and shock tower...
Rogman
Old Apr 18, 2014 | 07:06 PM
DUB's Avatar
DUB
Rogman
Placing the jack stand(s) as the way they show in the photo on a car that is assembled fully IS NOT what you want to do. Too much body flex can occur.
I have written in a post that I prefer to place the jack stands under suspension components/brake rotors...so the frame can settle.
DUB
Old Apr 18, 2014 | 07:53 PM
trippin's Avatar
trippin
Can you direct me to the post. I'm having no luck using the search. tks
Old Apr 19, 2014 | 12:33 AM
doorgunner's Avatar
doorgunner
OOOOOPS! I wasn't paying attention when I posted the frame /no-engine pic....sorry!
Old Apr 19, 2014 | 10:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The owner's manual and the jacking instructions on the jack storage compartment door show the proper jacking points. You can use those for jack stand placement.
Old Apr 19, 2014 | 05:25 PM
DUB's Avatar
DUB
http://forums.corvetteforum.com/c1-a...r-problem.html
I only commented on issues due to not correctly supporting the car...I do not know if this will help. Just make sure to TAKE THE TIME to get it RIGHT...or you can have a problem.
I would not for any extended length of time...over an hour...if that....and that is for changing a tire....which does not take long.
And if I do use a jack stand under the frame...and NOT the suspension (as mentioned)...because I am re-assembling the suspension...I use my floor jack and 2 jack stands...and the floor jack is used to raise up the sagging body/frame so not all of the weight is resting on the stands...the jacking configuration is triangulated...so to speak. Becasue I would have to be the one to fix a mess-up....I always make sure the frame is NOT allowed so sag down due to a jack stand is now a fulcrum.
People can do what you want...but let me tell you...due to these cars are getting older every year...and some more metal fatigue and issues will occur...what worked in the past may not be the way to do it today. Because I have ( as mentioned in other posts) have repaired frames on older Corvettes due to improper supporting of them over a few days.
DUB
To 73 vette conv
