Qjet divorced choke setup
Old Apr 18, 2014 | 08:27 PM
TWaldo's Avatar
TWaldo
Default Qjet divorced choke setup
Trying to reinstall divorced choke on newly rebuilt carb by Lars. Believe PO did not have it installed correctly, which added to "hard starting" experience.
New choke....is the rod connected as it is shown in pic...on right side? Or should there be tension and "wound around" so there is constant pressure?
How does the "cover" install so there is no interference? Thanks for any and all help...
Old Apr 18, 2014 | 08:37 PM
mrvette's Avatar
mrvette
Without going out a photo my camper, that setup looks so damn close to what is on my vehicle, it's not even funny.....
now having said that, I had to play with the choke rod a tad to get the thing to slam closed on a ~80f day in order to start, and then pull off after running a while.....I too have an aluminum manifold.....but being FLORIDA I blocked the hear river cross over passage with Plaster of Paris, but left the passage open enough under the heat stove, so it got hot enough to pull the choke off.....without heating the carb to the point it was hating life.....
Old Apr 19, 2014 | 12:23 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
http://forums.corvetteforum.com/c3-t...oil-setup.html
Old Apr 19, 2014 | 07:51 AM
TWaldo's Avatar
TWaldo
Thanks for link 63mako...found that in a search...newbie here...anyone have pics?
Old Apr 19, 2014 | 11:14 AM
MelWff's Avatar
MelWff
the choke coil is properly installed. Put the cover on it and follow the directions from the link repasted below, do you have the correct cover? have a picture?
Divorced Choke Systems (1967-1974)
 Disconnect the divorced choke rod from the lever on the passenger side of the carb. Leave it attached to the choke coil box on the manifold.
 Open the throttle slightly and fully close the choke by pushing on the lever arm that the disconnected rod normally attaches to.
 Push the choke rod all the way down into the choke coil until it hits the stop. If the engine is dead cold, it may already be bottomed out.
 At this position, the top of the choke rod should be level with the bottom edge of the choke rod hole in the lever on the carb.
 Bend the rod to obtain this relationship.
 Once complete, hook the rod back up to the lever.
 With the rod hooked up, push the choke rod back down to the seated position once again. This should fully close the choke blade. If the choke blade is not fully closed in this position, bend the choke intermediate rod that comes up through the body of the carb and attaches to the choke blade lever. Bend the rod so that the choke blade is fully closed.
 Remove the short piece of vacuum hose attaching the choke pulloff to the vacuum nipple on the carb. Attach a long (about 2’) vacuum hose to the pulloff.
 Crack the throttle slightly and push down on the divorced choke rod to close the choke fully. Release the throttle. Keep light finger pressure on the choke rod to maintain light closing pressure on the choke.
 Suck on the vacuum hose to retract the choke pulloff. If the pulloff does not retract, it must be replaced.
 With the pulloff fully retracted and light finger pressure on the choke rod, use your other hand to lightly push down on the forward lower edge of the choke blade to simulate to force of the air across the blade. This will open the choke slightly. At this point, measure the distance between the forward lower edge of the choke blade and the forward wall of the airhorn. This distance should be ¼”. You can use a ¼” drill bit as a simple gauge to check it. To adjust, bend the tang on the choke linkage where it contacts the choke pulloff rod.
 Re-attach the vacuum hose to the pulloff and the carb.
This completes choke adjustment for a divorced choke carb.
Old Apr 19, 2014 | 03:48 PM
TWaldo's Avatar
TWaldo
Here is the cover from PO...not sure if correct one. Doesn't want to "seat" properly without interfering with rod...
Old Apr 19, 2014 | 04:34 PM
63mako's Avatar
63mako
Might have to adjust (bend) the rod slightly to clear the cover. All the adjustment is done by bending the rods it looks like.
Old Apr 19, 2014 | 04:40 PM
TWaldo's Avatar
TWaldo
Thanks for all of the replies guys...see what I can accomplish after hosting Easter for 20+....
Old Apr 20, 2014 | 11:13 AM
Roco71's Avatar
Roco71
I had problems with the rod rubbing against the coil cover as well. My cover is a reproduction and I have nothing to compare it to so I am not sure how good of a reproduction it is. I just tilted it some but may come back and remove some material where it was rubbing with a Dremel.
Currently I have a aftermarket manifold on my car that may be contribute to the cover not aligning as the original.
Old Apr 20, 2014 | 11:38 AM
TWaldo's Avatar
TWaldo
Mine is Edelbrock also...anyone have pics of their functioning divorced chokes/covers?
Old Apr 20, 2014 | 12:27 PM
63mako's Avatar
63mako
Stock parts might not work with Performer intake without modification or edlebrock choke kit. The EDL 1931 rod from the coil to the carb looks different than yours to clear the cover. Might be able to buy the rod 9171 separate to work with your existing coil, cover and carb with the performer intake.
http://www.summitracing.com/parts/EDL-1931/
http://www.summitracing.com/parts/edl-9171/overview/
http://static.summitracing.com/globa...chokelinka.pdf
Hope this helps, Happy Easter Tom!
Old Apr 20, 2014 | 04:20 PM
Roco71's Avatar
Roco71
I hope to have mine back together midweek I am waiting on a replacement choke pull-off to arrive in the mail.
Old Apr 20, 2014 | 06:24 PM
Alan 71's Avatar
Alan 71
Hi TW,
This is the stock manifold so I don't know if these pics will be of any help you.
Regards,
Alan
Old Apr 21, 2014 | 07:08 PM
TWaldo's Avatar
TWaldo
Thanks to all for the replies. Happy to report I was able to install and adjust choke rod to specifications listed above. Started and ran well. Now onto the Lars rebuilt distributor installation...soon. Gotta get me some happy driving time in...after a long winter!
To Qjet divorced choke setup
