81 wiring ?
2.) If the engine has NOT been cranked for a long time. And I mean at least 6 months...and at that I really do not like it that long. I like engine being cranked about every 2 weeks to keep them oiled well and the internal parts do not run dry due to oil sheeting off of them. If it has been sitting that long...I would prime the ginseng first if it were in my shop.
3.) Coolant.
It all depends on how long you plan on running it.
DUB
I plan on doing that also. Motor has not been run in years as far as I know. It has a new timing chain, cam, intake and heads and hasn't been run since install. At least, that's what bubba told me.
Another ?,, on the starter harness I installed, it has 2 red wires, one black wire, one purple wire and two blue wires that go in to a plug. What are the blue wires for? I've read everything from electric fan to AC fan motor. I plan on removing the ECM and harness in the near future that was left in the car. How hard of a job is that? I'm guessing 3 banana.
Removing the ECM is a bit of fun because you are basically upside down getting to everything. I would remove the rear storage frame entirely if you do so...butt hat is just me...battery also..obviously.
If you have a 1981 factory shop manual...the wiring is clearly laid out in the book. Do you have one yet?...because as it has been written in some of your past posts...it is in your best interests to have one.
The blue wires are for other parts...and I do not have my manual with me at home....and usually there is a sensor in the cylinder head by the wiring so it will control the auxiliary electric fan...and may go the the blower motor...but without my book I honestly can not remember for a fact.
DUB
