Headers spacers
Old Apr 21, 2014 | 08:07 PM
Dream Bikes's Avatar
Dream Bikes
Originally Posted by REELAV8R
Looks like the boot is just touching the primary. I'd be tempted to double up the manifold gaskets and relieve the primary a little to get maybe 1/4" of clearance. Might require a heat shield tube to keep from cooking the boot.
Like one of these.
http://www.summitracing.com/parts/tay-2570
http://www.summitracing.com/parts/the-14250
Yes you're right, but I need more room to remove the spark plug without removing the exhaust header
Old Apr 21, 2014 | 08:10 PM
qwank's Avatar
qwank
Like one of these.
You can buy those metal boot shields from the dealer for about $3 each. 90s impala Ss had them
Old Apr 21, 2014 | 08:41 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by Dream Bikes
Thanks! So you have gasket between header and spacer and between head and spacer?
I started out with double gaskets. I had one blow out and did not have another set on hand, so I removed the gaskets and bolted it up tight and it has not leaked since.
I did cut the flanges as you can see in my pics, so that each connection is individual. I used a Fel Pro aluminum backed gasket set with individual pieces as patterns for the cuts on the flanges and for the spacers.
If i understand correctly, the original cast iron manifolds were bolted on without gaskets when new.
Old Apr 21, 2014 | 11:06 PM
REELAV8R's Avatar
REELAV8R
http://www.4wheelparts.com/Performan...Fc9AMgodYDQA3g
I wonder if these are any shorter?
Old Apr 21, 2014 | 11:33 PM
Dream Bikes
here's Champion RC12YC lenght :
http://www.sparkplugs.co.uk/graphics...ugs/RC12YC.jpg
Accel's don't seem me shorter but I don't know their lenght...
Old Apr 21, 2014 | 11:35 PM
Dream Bikes
Sounds good, I like your setup
You gave me an interesting point of view, thanks
Old Apr 21, 2014 | 11:38 PM
Dream Bikes
Which dealer? I have to buy it online, because I can't find it here in italy...
Old Apr 22, 2014 | 12:10 AM
lionelhutz's Avatar
lionelhutz
The Accel shorty plugs are shorter, I just can't tell you how much exactly. They're about just long enough for the boot to fit on though. Here's a better picture that may help you see the difference.
http://www.summitracing.com/dom/part...make/chevrolet
Beyond that, making spacers is a good idea that will work to get your clearance.
Old Apr 22, 2014 | 10:28 AM
redman76's Avatar
redman76
St. Jude Donor '09
I just installed the Accel 0414S on mine and they were something like 3/8"-1/2" shorter. The "S" in the part number indicates they are shorty header plugs. You can go online, post them questions with your engine specs and they will make a recommendation . . . they were very responsive (1-2 days) https://prestolite.zendesk.com/anonymous_requests/new
Old Apr 22, 2014 | 01:08 PM
toddalin's Avatar
toddalin
Will it even be feasible to add the spacers?
Consider the curvature of the #1 and #2 downpipes and the fact that the bolt that you need to get into the hole is going to be over an 1" longer. Are you even going to be able to wrangle a long bolt up and though that hole in the header flange, even before putting the spacer behind it?
Some headers make this impossible.
Old Apr 22, 2014 | 05:49 PM
scottyp99's Avatar
scottyp99
Studs, maybe?
Scott
Old Apr 22, 2014 | 06:10 PM
Dream Bikes
They're 3/8"-1/2" shorter than...??? As I wrote I aready have Champion's that are shorter than standard spark plugs...I will try to know the exact lenght of Accel's
Old Apr 22, 2014 | 06:11 PM
  #33
Dream Bikes
That's a good osservation, fortunately I can do it...I've tried just to know which spacer thickness I need
Old Apr 23, 2014 | 12:57 PM
  #34
Dream Bikes
I'm not able to found Accel's spark plug lenght...I've searched online but nothing. I only found detailed pics and I've tried to make a virtual misuration and seems that Accel's are the same ar a little longer than my Champion RC12YC which are 2.96" overall lenght. Could someone confirm it?
Old Apr 23, 2014 | 03:21 PM
  #35
scottyp99's Avatar
scottyp99
I know you live in Italy, and it's expensive to ship things there from the U.S., but I think the real solution here is to either get straight-plug heads that will work with your headers, or specialty headers that will work with your angle-plug heads.
Scott
Old Apr 25, 2014 | 11:02 AM
  #36
redman76's Avatar
redman76
St. Jude Donor '09
I'll pull mine tonight and take a photo for you comparing the Accel 0414S and Champion RC12YC . . . I have both.
Old Apr 25, 2014 | 05:43 PM
  #37
Scottd's Avatar
Scottd
So nobody wants to suggest this.....but you are going to need to beat the hell out of the tube and dent it for plug clearance. Ive got a set of beautiful Hedman ceramic coated headers on My BB and the same plug was ALWAYS burning out against the pipe. I had to beat mine up to get an extra 1/4 inch clearance.
To Headers spacers
Old Apr 25, 2014 | 07:58 PM
  #38
Dream Bikes
That's great! I will wait for news from you
  #39
Dream Bikes
Yes 1/4" will work but 1.1/8" it's too much!
Old Apr 25, 2014 | 09:25 PM
  #40
redman76's Avatar
redman76
St. Jude Donor '09
I measured both plugs, same way you had in your photo. Also, found out my old plugs are RN12YC, sorry for any confusion.
CHAMPION RN12YC - 8.0cm
ACCEL 0414S - 7.2cm
So looks like the Accels are .3cm shorter than the RC12YC (7.5cm) that you have.
