missing cable to heater control
Old Apr 24, 2014 | 04:22 PM
chevyfiftynine's Avatar
chevyfiftynine
Default missing cable to heater control
Hi Guys,
I'm in the middle of rebuilding the interior of my 350 manual '69. When I came to refit the centre console I found two cables for the vents - that's the ones with the loop of wire at the end - but only one for the heater control. Surely there must be one for each thumb wheel but search as I might I couldn't find another one. The one that's there turns a spindle up at the heater box. Is there only one heater cable with the curly end and if so which side does it go one? Does it go round a vertical post at the bottom of the unit?
Thanks, Barry.
Old Apr 24, 2014 | 04:40 PM
oledave60's Avatar
oledave60
You didn't say if you have A/C or not, but here is a picture of a control with A/C. This is the bottom, so from the top the cable attaches to the wheel on the right. There is a round push nut that secures the cable to the post.
Old Apr 24, 2014 | 04:42 PM
Alan 71's Avatar
Alan 71
Hi B,
There's only one cable for the heater control.
The right side 'wheel' control the temperature of the air being supplied … hot or cold. The cable opens and closes a door in the heater box by attaching to a lever on the top of the box.
The left side wheel controls vacuum operated functions.
Regards,
Alan
The side view that goes with Dave's bottom view.
Old Apr 25, 2014 | 04:12 AM
chevyfiftynine
Thanks Alan and Ole Dave - must've spent three hours looking for a cable that doesn't exist! I should have said it was without A/C but your diagrams have clarified how to attach the cable. Now I can get on with the rebuild.
Regards, Barry.
To missing cable to heater control
