Voltage gauge not working
Old Apr 24, 2014 | 09:56 PM
GreenDream's Avatar
GreenDream
Default Voltage gauge not working
Wiring diagram indicates all gauges are on the same circuit and fuse. All other gauges work. Should I then assume that I have a bad gauge or be looking somewhere else first?
Old Apr 25, 2014 | 01:01 PM
brrujo's Avatar
brrujo
I put 3 in my 73 before I got one to work. Check your voltage across your volt gauge with the engine running. If charging system is working properly, it should read around 13.75.
Old Apr 25, 2014 | 02:00 PM
GreenDream's Avatar
GreenDream
Thanks.. I will try that..
To Voltage gauge not working
