Have any 81 owners purchased and installed the true dual exhaust from corvette central ? If so do you have any pics from underneath ? I just want to be sure it really is bolt on and no mods. Corvette central's site throws me off a bit as they show an image of a cross member with 2 holes for the pipes...our 81's don't have that so I just want to be sure it bolts up and clears....
Quant,
Yea in pulled that as well so I just want to be sure I won't have any clearance issues
The original routes under the pass side with the giant cat...I assume the duals route in that same tight space ...but for 700+ bucks I don't want to assume wrong
I had it on my '81 when it was pretty much stock and it fit perfectly. Once I added long tube headers I started having fitment issues. But my kit wasn't designed for headers
Qwank - thank you. I'm going to get the full kit with patriot headers as well.
Unless you recommend a diff set of shorty headers that will bolt to that kit ?
***if *** I swap the original 350 out, I'm putting a zz4 crate in it and that Is compatible with these patriot headers
I bought one for my 80 last year. Very easy installation, but I did have to drill two holes in my cross member to mount. Clearance is good, easy install, no mods needed, and sounds great.....
Shorty headers are shorty headers so the ones that come with it should be fine. the system is designed to work with those headers only so i wouldn't change them. I'm pretty sure they will work with the ZZ4
