Clear tube in differntial
Old Apr 29, 2014 | 06:21 PM
bluedawg's Avatar
bluedawg
Originally Posted by hugie82
I have to agree with mike... The chances of damage is almost 0 but it would hurt to try fishing it out or a good excuse to swap gears!
I can't see it hurting it either, but the agravation of not getting it out would drive me nuts, I bet I could get it out with a set of mechanics fingers, the temp wouldn't be enough to melt the plastic and even if it did it wouldn't hurt any thing. Like I said, my gear oil looked like silver paint when I got it, the po didn't use posi additive which ground the friction material off of the clutch plates and I drove it for 3,000 miles after I got it before pulling the diff cover to replace it with the hd diff cover. bearings looked fine. Have put 10,000 miles on those bearings since, no issues, so I don't think that plastic particles would do any damage and if it were mine I'd try to fish it out and if that didn't work I'd probably pull the diff cover due to frustation.
Old Apr 29, 2014 | 06:40 PM
7t9l82's Avatar
7t9l82
i agree with the mechanics fingers, that could be your best shot. chances are it would stay at the bottom and little chance it would get picked up. still the fact remains it isn't a factory approved modification.
Old Apr 29, 2014 | 06:54 PM
wpirie's Avatar
wpirie
3rd Gear
Don't worry about it. It's a piece of soft plastic. No damage will occur.
Old May 1, 2014 | 05:34 AM
wilesre's Avatar
wilesre
I did that to a manual transmission and it broke a bearing. That plastic got between the gears and spread the shafts. Probably will do the same thing in the ring and pinion or spider gears/posi unit.
Old May 1, 2014 | 01:54 PM
LT-1 kid's Avatar
LT-1 kid
if Gary from vteck thinks its fine I would not worry about it.
Old May 1, 2014 | 02:00 PM
bashcraft's Avatar
bashcraft
Originally Posted by scrappy76
If it goes to the bottom and never gets in contact with the gears or the posi system, you will be ok. If it does get picked up it will not only break up into tiny pics but there could be melting involved and this will most likely do damage to your gears,bearings,seals, and clutches.
Though its alot of work. I would try to get it out even if that involves taking the Diff cover off.
If your rear end gets hot enough to melt plastic, you've got bigger problems than just a piece of tubing being in there.
Old May 1, 2014 | 02:10 PM
bluedawg's Avatar
bluedawg
For sure.
Old May 2, 2014 | 11:36 PM
wheatpj's Avatar
wheatpj
Originally Posted by Vtechcorvette
Over the years we have found clear tubes and the tips off the gear bottles. Some were torn up but they never bothered the gears or bearings.
Here is you answer.
Old May 2, 2014 | 11:38 PM
wheatpj's Avatar
wheatpj
Old May 3, 2014 | 12:00 AM
75roadster's Avatar
75roadster
Cruising
Thanks so much for the feedback. I hadn't expected such a response but it's much appreciated. The divergent opinions aren't a surprise as they pretty much mirror what I've had from folks "offline". For my own peace of mind I'd like to get it out so I'm waiting for an inspection camera to arrive and then I'm going to take a look inside the differential. I think if I can see it I'll be able to retrieve it. I will let you know how it works out when I get the camera. Thanks again, Gary
Old May 3, 2014 | 12:06 AM
Tom454's Avatar
Tom454
Buy one of those plastic magnets and fish the tube out.
Old May 3, 2014 | 01:52 AM
bluedawg's Avatar
bluedawg
Good luck, happy fishing.
Old May 3, 2014 | 11:47 AM
  #33
REELAV8R's Avatar
REELAV8R
I don't think it will hurt either, but if you want to get it out here is what I would do.
Drain the oil out first.
Then get your shop vac and duct tape a piece of copper tubing or small diameter vinyl hose into your existing hose and start sucking around in the diff.
On second thought the vinyl tube would probably work better since it can flex.
Just have it be thick walled stuff so it doesn't just pinch shut while bending it around.
Old May 14, 2014 | 02:10 PM
  #34
75roadster's Avatar
75roadster
Cruising
OK Guys, thanks for all the advice and the great suggestions. The bottom line is that I had success. I was able to remove the tubing using an inspection camera and flexible grippers. I taped the camera head about an inch above the claws of the gripper so the two tools could be manipulated as one and I could see the claws open and close in the camera. Then I went fishing, found the tube and was able to grab it with the claws and pull it out. Hallelujah!! The differential is now filled with fresh fluid and modifier and all is well. I've attached a pic showing the result. Thanks again for your help. Gary
Old May 14, 2014 | 02:11 PM
  #35
qwank's Avatar
qwank
awesome!
Old May 14, 2014 | 02:19 PM
  #36
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I once swallowed a dime.
Old May 14, 2014 | 02:24 PM
  #37
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
great fishing story !
... how big was that Fish ?
To Clear tube in differntial
Old May 14, 2014 | 03:01 PM
  #38
thegazman's Avatar
thegazman
Default thegazman
Originally Posted by Mike Ward
I'd just do a frame off.
Old May 14, 2014 | 03:07 PM
  #39
7t9l82's Avatar
7t9l82
now practice getting needle bearings from a roller lifter out through a dipstick tube show off.
good job
Old May 14, 2014 | 04:38 PM
  #40
Mike Ward's Avatar
Mike Ward
How did that work out for you?
