Annoying light
Old Apr 30, 2014 | 08:35 AM
USMC1371's Avatar
USMC1371
Cruising
Default Annoying light
I have a 1973 Corvette Stingray. When I turn my lights on my Fasten Seat Belts light comes on. How do I shut it off?
Old Apr 30, 2014 | 08:41 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Are you saying it stays on until shut down?
Old Apr 30, 2014 | 09:42 AM
76Rat's Avatar
76Rat
I sounds as if you have the seat belt light and headlight connections backwards in the dash.
Old Apr 30, 2014 | 11:07 AM
scottyp99's Avatar
scottyp99
Fasten your seat belt?
Are you saying that when you switch the headlights on, the seat belt light comes on, even if the seat belt is fastened? Does it work properly with the headlights off?
Scott
Old Apr 30, 2014 | 11:15 AM
Mike Ward's Avatar
Mike Ward
Bubba has farqued up some of the wiring.
Old Apr 30, 2014 | 11:48 AM
zuendler's Avatar
zuendler
Your bulb plugs are mixed up behind the bezel.
You have a normal back light bulb in the housing where the seat belt bulb should be.
If it is dark in your car with the lights off you may see one gauge with a back light until you turn the seat belt light off.
To Annoying light
