73 hood prop
Old Apr 30, 2014 | 08:14 PM
trippin's Avatar
trippin
Default 73 hood prop
Does anyone have a pic of the hood prop and how it is installed. I just can't figure out why mine is going thru the channel other than someone put it on wrong and I'd just want to fix it. Tks.
Old Apr 30, 2014 | 09:57 PM
GreenDream's Avatar
GreenDream
I cant say for sure without going out to look at mine. The notch is in the right direction but it looks like the top mount might be flipped.
Old Apr 30, 2014 | 10:27 PM
redwingvette's Avatar
redwingvette
Here is a picture of mine
Old Apr 30, 2014 | 10:42 PM
hwcoop's Avatar
hwcoop
here's a close up , looks like yours tore the bracket out of the fibre glass ?
Old May 1, 2014 | 07:01 PM
trippin's Avatar
trippin
tks for the help and pics. hwcoop where your brackket holding your wires, mine is directly under the bolt thru the fiberglass. I guess what I'm saying is your's looks to be about an inch or so back. I can't see where i could bolt my bracket there.
Old May 1, 2014 | 07:36 PM
Alan 71's Avatar
Alan 71
Hi T,
The bolt in the gutter is secondary to the 2 bolts that go through the prop's lower brace into the metal support in the fender well for the hood hinge, radiator core support, and the hood prop.
Here are some pictures from both sides.
Regards,
Alan
The upper 2 bolts are from the hood hinge and the 2 coming from the side are from the hood prop.
Old May 1, 2014 | 08:02 PM
Mooser's Avatar
Mooser
But I do believe they changed the design slightly sometime in mid 73 and the bolts on the side went to a single bolt and maybe slotted?
The bolt in the trough was the same though
But I'm frequently wrong so maybe not, 72 looks like Alan's pic. Early 73 should be the same also
M
Just for giggles, here a view that doesn't show up much (again a 72) not exactly where I thought it rested somehow...
[IMG][/IMG]
Old May 1, 2014 | 08:29 PM
trippin's Avatar
trippin
Exactly the best pics I could have ever asked for tks so much.
Old May 1, 2014 | 08:34 PM
trippin's Avatar
trippin
[QUOTE=trippin;1586799648]Exactly the best pics I could have ever asked for tks so much. Gonna start another thread about have any of u would try struts
Old May 1, 2014 | 08:40 PM
Mooser's Avatar
Mooser
Alan's picture library is right up there with the AIM in my list of usefully references, and in many cases better or at least clearer
Old May 2, 2014 | 06:08 AM
LudemJo's Avatar
LudemJo
I wish my car looked like Alan's...probably won't happen in this lifetime.
John
To 73 hood prop
