Motor is OUT
Went smoothly, although a few small problems.
My Oil Sending line broke when I was removing it from the block. It broke off right where the fitting goes into the block. I'm hoping I can attach a new compression fitting to it...
Transmission is at the trans shop One of the ears on the tailshaft was busted off, which means a new tailshaft/housing/case. $225.00, plus any other work that needs to be done to it.
Bellhousing has a small crack, I'm going to take it to a welder this week...It's small, shouldn't be a big deal. Worst case, new bellhousing (should be fixable)
Motor should be ready this month...
