Today I got my circuit card from willcox, replaced the old burnt up one that was pegging past 7k, and would jump around whenever I was braking or signaling.... With the new card it still pins at 7k, but it doesn't jump around as current jumps across circuits... so that leaves the coil off the distributor and the wiring to the tach...
My question is where can I get the coil for the tach?
Well it doesn't jump around at all any more, it pins at a consistent voltage, the old card had a huge black spot that encompassed pretty much everything on the right side of the card, so it was toast anyway, my next idea would be the coil mounted to the intake manifold has failed... I hope it's not wiring, I'm an avionics technician in the air force, so wires don't scare me... But I don't want to open the can of worms under the dash just yet, not until I can buy a new harness entirely
What's the analog movement you're talking about? I'll get the tach out to you probably next week, you guys wouldn't happen to carry the capacitor/inductor coil thing attached to the intake manifold would you?
Are you talking about the tach filter? You can by pass it. Just plug the tach wire into the dist. I have not run a filter in 12 years and tach runs fine. See if by passing makes a difference. This is the first step before opening a can of worms
I got 12vdc from battery, continuity on ground, & the dist. put out a little over 12vdc at idle (in the console), and rose under acceleration... I bypassed the filter, same dist. output... I hijacked 12vdc from the alternator, found a good ground, & connected the dist. Same problem, so that leaves the new card and the tach itself as the source of the problem
Suddenly it decided instead of sticking at exclusively 7000 it would sit around 4500 to 5000, and then move slightly under acceleration until jumping to 7000, the counter balance inside the tach is off... and I broke the needle trying to rezero it, so I'll need to buy a tach either way
