I had my car aligned by a shop in Dallas recently. The car drives straight and feels great, but in appearance, it looks a bit extreme so I was hoping to get some input. For reference, most of the suspension components are new (including new offset trailing arms).
I took to the shop the VBP spec sheet and asked for them to mimic the advanced street specs. Visually, the front wheels appear to be standing almost completely vertical while the back wheels have an obvious lean to the center at the top of each wheel. How obvious should this be to the naked eye? If I had to guess a measurement with no tools I would think it's a couple of degrees negative camber versus the 0.50* on the sheet, but perhaps I'm missing something? As I mentioned, the car drives much better currently.
My friend over the other day asked me immediately about the angle, so it's apparent enough to others.
I may be able to go by a Firestone and have them give me the actual measurements, but they've refused to do the alignment in the past (along with 90% of other shops in the area).
May should have looked sooner. The camber rods aren't tightened down. I can turn the tightening bolts with my bare hands.
If I play with the angle doing the little mathematic trick, should I be able to tighten them down myself and still have the car in pretty good alignment? Will the other alignment specs have to be reconsidered once that's adjusted?
My alignment is -0.7 degrees front and -1.2 degrees rear. It is very noticable just by looking at it.
I also have vbp camber rods. Those lock down nuts always come loose. I am starting to think the lock down nuts need some lock-tight.
I use an old plastic level, cut to fit the face of the wheel rim for easy measurements while aligning my wheels.
Excellent idea for DIY alignment. I used the tire--not as good!)
Do you have OEM strut-rods......if so, you need the special cupped-washers/spacers----1 pair per inboard bushing-to keep the strut-rod from slipping out of adjustment....it takes some effort to get them INSIDE the bracket. (ignore the chrome Harley mufflers)
I have the rear wheels set at 0* camber for now ---I'll watch the wear pattern on the tread closely because the previous owner installed 295-15 rear tires!
Let us know what you discover. DO NOT BACK THE CAR BEFORE PUTTING IT IN PARK---ALWAYS DRIVE FORWARD/THEN PUT IN PARK OR BLOCK THE FRONT WHEELS FROM ROLLING when adjusting the camber or Toe.
Too late, I can't ignore the Harley muffler! You must now post a video of your car running
Back to the alignment .... If your adjustable rods were loose, you have to go back and get them to align it again! That's on them! If those rods turn a half of turn, your alignment is off now and you have no way of knowing. As far as the wheels being tipped in maybe due to ride height or when they drove it up on the rack, the rear wasn't settled into ride height. My rear is tipped in a little but you have to step back and really look to notice. You can really notice when you launch or do a burnout that the wheels tip in as the suspension squats but that's their design.
I'm going through alignment now since I redid my entire front end. While thinking about camber I remembered I had a little angle gauge for my tablesaw. It's digital and quite accurate. Going to give it a try.
I have 30,000 miles on the little red truck tires in the background photo.....using the "string method" and the carpenter's level on the rims/angle-finder gauge on the front-end caster.......appears as though they're good for another 30,000 miles (times to rotate them----maybe?!?!)
I didn't have them come loose on the first ~400 miles or so. I've got their tie-rods as well and haven't noticed anything too loose, but I need to revisit every bolt looks like. I'm thinking the alignment shop didn't tighten them down after they were done, or not well enough anyway. I spoke with the shop I actually paid for the alignment and they seemed more than willing to adjust it for me so now I've just got to get my back in order so I can get under there and tighten them down for the drive over.
Unless you're planning on using the car for drag-racing and have locked the camber curve through a six-link setup or similar, you should run a bit of negative camber to account for tire roll when cornering - especially on a meaty tire like that.
So i used my digital angle tool and it worked awesome. Benefit on this is you zero it out on the surface your on then take the measurement. accuracy on the cheap.
I cut the level (length) so it just comes in contact with the wheel rim - therefore it is a true reading of the wheel angle. Using a level that touches the top and lower edges of the tire could give an erroneous reading - the lower portion of the tire is usually bulged out.
