E brake issues
Old May 15, 2014 | 03:06 PM
blue by you's Avatar
blue by you
Default E brake issues
I had a noise in the drivers side rear wheel. I took off the tire and drilled the rotor and removed it, and 2 smashed springs fell from the e brake. How hard is it to replace the srings seems like there is not much room to work.
Thanks in advance
Old May 15, 2014 | 03:49 PM
mrvette's Avatar
mrvette
IF you don't have to pass an annual inspection, just fuggetaboutit.....
they never seem to work worth a damn anyway.....just look at it, common sense....5" of hub trying to keep 3300 lbs from rolling off a ~27" tire....right.....
Old May 15, 2014 | 04:36 PM
blue by you
That'sat i was thinking, i don't go to inspection
Old May 15, 2014 | 07:44 PM
DUB's Avatar
DUB
In my opinion....and not meaning to get anyone upset.
It has to do with SAFETY. Possibly one day...you might run into an issue where you will wish that you had a secondary stopping source....other than downshifting.
And sure as shooting...if the car never had a EMERGENCY BRAKE...we would be all bitchin' and moaning that someone should find way to get one to work. Funny how that comes around full circle. Just like how some remove the spare tire...and hope they never need it.
Yes...these two springs are no fun to install but I do them a lot each year.
DUB
Old May 16, 2014 | 05:01 AM
mikep3's Avatar
mikep3
I used this article,
http://www.corvettemagazine.com/tech...brake-rebuild/
It was not fun, 4 hours on side one and 20 minutes on side two. It works great if not on a hill. Google e brake for c3 corvette and you can find several articles and u tube stuff.
Old May 16, 2014 | 07:23 AM
bashcraft's Avatar
bashcraft
It's not an "emergency brake". It's a parking brake. It was never intended to stop the car in an emergency.
I can't remember ever using the parking brake in any of my cars.
That said, I rebuilt the parking brake on my vette about 6 years ago, just because I wanted to punish myself.
Old May 16, 2014 | 08:02 AM
blue by you
Thanks for all of the input, it didn't look to be a fun job. I gues i'll save it for a rainy day
Old May 16, 2014 | 09:15 AM
BigAl5611's Avatar
BigAl5611
Lightly but completely compress the spring in a vise and run dental floss thru the retainer and out the bottom of the spring. Tie the floss very tightly using 2 to 3 knots to reduce slippage. Hold the spring and loosen the vise and turn the spring and reclamp it so you tie the other side. This makes the springs very to install. Once installed use a barbecue light to burn the floss and the springs will seat in place.
Old May 16, 2014 | 06:09 PM
DUB's Avatar
DUB
With all due respect...it is matter of semantics. Parking brake...or Emergency brake....how ever you feel best calling it or using it or not using it is all up to you.
I KNOW it was not designed to stop the car....but if you loose the hydraulic brakes...using the "parking brake" will slow you down quite significantly.
I know many people who do not use many items on a car...but just because people do not use them does not make them useless. I guess it is whatever makes them happy.
I know one thing...if I were to jump out of an airplane...I not only want my primary parachute...but I know I would also have a back-up...just in case.
DUB
Old May 17, 2014 | 06:40 AM
gcusmano74's Avatar
gcusmano74
If your car is an automatic, IMHO, you don't need it. Required only with a manual shift.
My two cents.
Old May 17, 2014 | 06:10 PM
DUB's Avatar
DUB
My two cents.
Two cents worth coming back at you.
IF you park your automatic Corvette on an incline...when you go to shift out or park...it can be/will be really hard to do so in many/most cases. Level ground is not an issue...but go park on a hill and see how hard it is to shift out of park...BUT if a person applied the parking brake when they still held the car in position with the brake pedal...when you go to shift out of park it will easily shift.
DUB
So...lets see...I have read that these are not needed or used...parking/emergency brake, wipers, catalytic converters, EGR valves, smog pumps, spare tire and jack, and sun visors. Simply amazing.
Old May 18, 2014 | 09:16 AM
gcusmano74's Avatar
gcusmano74
Yes. Imagine the weight savings...........................
Old May 18, 2014 | 08:15 PM
kydirt's Avatar
kydirt
I used the dental floss method. worked good.
Old May 18, 2014 | 08:26 PM
1974CorvetteJimCr's Avatar
1974CorvetteJimCr
Default reduce the strain on the parking pawl
That dental floss procedure sounds cool!
The parking brake (a.k.a. emergency break) reduces the strain on the parking pawl in an automatic transmission. One should set the parking brake while one's foot is still on the brake pedal and before shifting into “park”. This reduces the strain on the parking pawl. This small procedure can save hundreds if not thousands dollars in repair or replacement of a transmission.
Like Benjamin Franklin said, "An ounce of prevention is worth a pound of cure".
Old May 19, 2014 | 07:45 AM
bashcraft's Avatar
bashcraft
How many parking pawls have you needed to replace?
Old May 19, 2014 | 02:18 PM
blue by you
I wiil get around to fixxing it jsut wanted to know if it was a pain like it looks thank to all that have commented
Old May 19, 2014 | 05:12 PM
1974CorvetteJimCr
Default parking pawls
One. I actually had to have the entire transmission rebuilt due to the damage.
To E brake issues
