Yesterdays Dyno Test!
Old Jul 22, 2002 | 05:20 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Yesterdays Dyno Test! (Jman)
GS- How much did the dyno runs cost you? I'd like to get my car dynoed pretty soon.
Here in Miami - the price is $60 for 3 pulls and $85 with A/F
At "Dyno Day" in Orlando I paid $45 for 2 pulls w/out A/F
:cheers:
Olivier
Old Jul 22, 2002 | 05:34 PM
Lt1er's Avatar
Lt1er
Default Re: Yesterdays Dyno Test! (GrandSportC3)
I've never felt the need for the dyno. Especially here at nearly 5000 feet. My car is to pretty to tear up racing. You should do testing with an A/F ratio and something monitoring your timing. Your cam like mine should be making power clear out past 6500
Old Jul 22, 2002 | 05:39 PM
GrandSportC3
Default Re: Yesterdays Dyno Test! (Lt1er)
Currently the engine is peaking around 5300 - that's more than 1000 RPM below this mark :eek: :eek:
:cheers:
Olivier
Old Jul 22, 2002 | 05:53 PM
Lt1er's Avatar
Lt1er
Do you have your cam card? I need the even numbers and I could run it through my DD2000. That big of a cam in a 383 shouldn't have peak hp untill 6000 or so. Also don't you have 2.05/1.60's in those Dart heads? also I need to know header size.
Old Jul 22, 2002 | 05:55 PM
GrandSportC3
I don't have the cam card :(. The engine builder told me that the HP is supposed to peak at 6200... And YES - the valves are 2.05/1.60's
Header size it 1 7/8's primaries and a 4 inch sidepipe (currently with CCI 2-disk inserts)
:cheers:
Olivier
Old Jul 22, 2002 | 06:41 PM
Matt Gruber's Avatar
Matt Gruber
you can have "bungs"(nuts) welded to the bottom of your way big 1 7/8 headers (if you don't want to buy a spare set for testing.) Plug it after and no one will see it.
it's not a big deal; just do it!
Old Jul 22, 2002 | 06:56 PM
GrandSportC3
Default Re: Yesterdays Dyno Test! (Matt Gruber)
I am thinking in putting a A/F gauge into my Vette... Would be nice to have a oxygen sensor in each primary pipe and one in each collector and hooking them up with 10 position switch to an A/F gauge. That way I could check the A/F of each cylinder and each side.. However - this would be very expensive.. How much are oxygen sensors???
:cheers:
Olivier
Old Jul 22, 2002 | 07:02 PM
GrandSportC3
I just checked the price for a oxygen sensor + harness at Summit. It's $89.95 :eek:... So it would be way to expensive to hook up 10 sensors...
I might just hook up one in the left pipe!!
:cheers:
Olivier
Old Jul 22, 2002 | 07:10 PM
Matt Gruber
the gauge i use reads 2 cyl at once.$100
sensors 2x$20=40
8 would be 160, maybe less if you shop around.
there is no need for 10 unless you get a viper v10.
i use mine as a tool, and swap it from car to car as needed. your idea with a rotary switch is :cool: if you don't mind spending the $$$$$$
Pro's run 8 with matching gauges and a video camera; they study the runs on replay with :cheers:
Old Jul 22, 2002 | 07:19 PM
GrandSportC3
sensors 2x$20=40
I was thinking in putting one in each primary pipe (8) + 1 in the left collector and 1 in the right collector for a total reading for all 4 cylinders of each side... Maybe I'm only going to place 1 sensor in each collector and connect them to a 2 position switch to be able to switch between the left and right reading! I would replace my clock with the A/F guage. That should be enough for my needs...
:cheers:
Olivier
[Modified by GrandSportC3, 6:21 PM 7/22/2002]
Old Jul 23, 2002 | 09:17 AM
QuickVet's Avatar
QuickVet
why the black smoke? :confused:
Old Jul 23, 2002 | 09:23 AM
GrandSportC3
Default Re: Yesterdays Dyno Test! (QuickVet)
ran too rich (at certain rpm's).. some major tuning is required... I will also change the carb to a mech. secondaries...
The whole setup has to be dialed in and adjusted. There is no smoke during regular driving - just at full throttle...
:cheers:
Olivier
Old Jul 23, 2002 | 04:23 PM
  #33
QuickVet's Avatar
QuickVet
if you lean it you will see more power :yesnod:
Old Jul 23, 2002 | 04:26 PM
  #34
GrandSportC3
Running leaner should give me more power and also removing the inserts in the exhaust!!!
:cheers:
Olivier
