A/C Compressor problem
Old May 22, 2014 | 09:22 PM
78INDYPACER's Avatar
78INDYPACER
Default A/C Compressor problem
Hello everyone!
I have a 78 L48 Pace Car that is blowing warm air out of the vents when Max/Norm A/C switch is on. I checked the compressor and it is turning with the belt while engine is running. However, the clutch does not engage when the A/C switch is on. If the unit needs a recharge would this be the cause of the clutch not engaging? Clutch will not budge by hand. Can the clutch be replaced without replacing the whole compressor and can you still recharge with R12? or is a conversion to R134a in order?
Thanks in advance, Jim
Old May 22, 2014 | 10:23 PM
REELAV8R's Avatar
REELAV8R
The clutch will not engage unless there is enough freon in the system to satisfy the low pressure switch.
R-12 is still available , but expensive.
Changing to 134a is possible, but involved and still takes some $$$ and time.
The clutch can be changed independent of the compressor. If you put 12 volts to the plug on the compressor you should hear the clutch click. It's just an electro magnet to activate the clutch.
Old May 22, 2014 | 11:07 PM
TimAT's Avatar
TimAT
Can you turn the center of the clutch by hand? Engine off. IF the center is locked then your compressor is most likely toast. Could be the front clutch bearing, but the odds of that are not in your favor.
Old May 23, 2014 | 09:03 AM
augiedoggy's Avatar
augiedoggy
I converted my 74 original ac over to r134a 3 years ago for about $50... They do make additives to make the r12 lubrication oil compatible with r134a and the recharge/conversion kit I bought at advance auto had a form of stopleak in it which must have sealed the hoses since I read here somewhere that they are normally too porous for R134a. That said I understand everyone's mileage may vary.
Old May 23, 2014 | 10:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Any automotive AC shop can test your system and recharge the refrigerant. They can also give you the skinny on converting to R134a if you want to make the conversion.
Old May 23, 2014 | 01:40 PM
78INDYPACER
Thanks Mike!
Old May 23, 2014 | 01:44 PM
78INDYPACER
Default A/C compressor problem
Thanks for the quick reply! I'll try applying 12V and listen for the click. Should the clutch be free to be moved by hand with engine off or on. Belt is spinning the compressor pulley
Jim
Old May 23, 2014 | 03:27 PM
REELAV8R's Avatar
REELAV8R
Jim
I assume you mean with the engine off to turn the compressor by hand. Unless the system is empty and the belt is off, you're probably not going to be able to turn it by hand. You'd be working against the freon and oil in the pump and that takes lots of power to do.
If you want to test to see if the pump is seized or not you can bypass the low pressure switch by applying 12v directly to the compressor clutch with the engine running.
Do it in such a way that you can immediately remove the 12v in the event that it is seized. Also in a way that you are clear of rotating parts. Using the original plug and tapping into the wires upstream might be a way to do it safely.
If it is seized you're gonna hear an awful lot of noise when the clutch engages and tries to turn the compressor.
If it's not seized the compressor will run fine. Don't try to cool the car that way though. It needs the freon to help move the oil through the compressor, so running it with too low of freon would also present a lack of lubrication to the compressor and ruin it if you continued to operate it that way.
Old May 31, 2014 | 12:37 PM
Rubetech's Avatar
Rubetech
Okay fellow's I have some a related question. I took my 78 SA in to have the A/C charged to see what all needed to be replaced. The did the retro fit, and charged the system to find that my compressor was leaking bad and needed replaced. To get the parts and labor warranty I had to replace the dryer and oriphsis, or however it is spelled. The hose would not come off the dryer so they replace that too. $966.00 later!
I have a whole new A/C system except the condinser which was in good shape. So the new system works and it blows cold air, I wish it blew a bit harder, but I may end up replacing the switch and blower at a later date.
My question is, when the ac is on and the car is in idle the ac compressor makes a noise it is like a tink noise every few seconds. Thoughts? When you accelerate it goes away, I don't want to ruin anything.
I noticed i lose a fair bit of power with the ac on but I supposed that is to be expected. Any and all thoughts are always appreciated.
Old May 31, 2014 | 02:09 PM
Rubetech's Avatar
Rubetech
I figured it out, it was the belt slapping the brace at the bottom where that little belt "skip pad" is located.
Does anybody know if there is a newer ac bracket for these that fit the new compressor's better. I have it as tight as the current bracket allow's. I am planning on a new set of belts when I do the water pump next anyway!
Old Jun 1, 2014 | 06:31 PM
bschuus's Avatar
bschuus
My a/c belt did the same thing at idle and what I never put back on when I had the valve covers off was the bracket that went from the back of the compressor to the intake manifold bolt. Without that bracket the compressor was shaking no matter how tight I made the belt. Of course that's if your bracket is missing.
Old Jun 21, 2014 | 03:03 PM
Rubetech's Avatar
Rubetech
So I am wondering if there is a different bracket that is supposed to be used with the new A/C compressor I bought. It lines up with the other pulley's in the system, but is not as long on the back side as the old one was. The belt is as tight as I can get it. Even know the lower, belt guide is disconnected, and pushed down and out of the way, I am assuming the repair guy did this for clearance, it is now tapping on it again and making that sound again. It makes me wonder if this new A/C compressor is supposed to be uses with a different bracket. I do not know how old the belts are, but there isn't any dry rot and it looks good and feels tight.
Any Advice would be much appreciated.
Thanks again.
Brent
Old Jun 21, 2014 | 08:56 PM
bschuus's Avatar
bschuus
I can try and send you pics of my compressor if you want.
Old Jun 26, 2014 | 01:08 PM
zoomee's Avatar
zoomee
7th Gear
I did this same job myself on my 78. I replaced the blower and fan wheel while I had the drier out. The wheel was cracked and warped. It looked near impossible to change it with drier in there. Pull your glove box and check your duct work in the dash. Mine was leaking and blowing all the cold air in there keeping the instruments nice and cool! I used duct tape to seal them up and get much better airflow now.
Old Jun 26, 2014 | 02:40 PM
ezobens's Avatar
ezobens
GM went backwards IMO when they moved from the A-6 to the R-4 style compressors. The A-6 was bulletproof but it was heavy and required a lot of power to run. The R-4 is smaller and somewhat more efficient power-wise but is fragile. I seem to replace R-4 compressors as often as I replace brakes on some cars-
R-134a with an R-4 is not something I would run on a vehicle that is driven regularly as the higher pressures required for R-134a will make an already fragile compressor weaker yet.
Can it be done? Sure....
Personally, if I was going to switch to R-134a, I'd follow through and replace the hoses, install a Sanden compressor and install a parallel flow condenser. Anything short of that is a compromise.
Just my .02
To A/C Compressor problem
