1973 Temperature gauge issue. How to fix?
Would that make a difference? I know that the temp sending unit says made in usa on it, but not sure if it is reading right.
Any tips on how to figure out which part is making the gauge read only 150?
Will changing to the correct gauge change anything?
Here is where a problem can begin.
YES..it can make a BIG difference...regardless of the gaueg and the sending unit. THEY BOTH have to match each other.
Here is what I do...because I just did it on a 74 I am working on...I send the gauge cluster and the sending unit out and have them matched with each other. You can buy numerous sending units and they can all be off. So by my gauge guy getting water heated to 180,200 or 210 degrees...whatever is at the 12 o'clock position on the face of the gauge...he will adjust the gauge to read correctly.
YES it can and then again it may not...it all depends in how the sending unit is made and how it reacts to heat and what OHMS is send to the gauge to make it read correctly.
DUB
http://www.lectriclimited.com/shoppi...p?id=871365024
The temp sending unit in my engine is orginal to the engine, but since the engine is NOM, who knows what year it is from.
I will change out the gauge to the right one (1972-1974) and see if that makes any difference at all.
The oil inside and the spring have to be correct. They can be a bit touchy. Buying one from "whoever" else can lead to a major cluster.
DUB
DUB
We are working on a gauge resistor that will allow you to make the gauge match the sender and should be finished with it very soon.
Willcox
AGREED...the senders/gauges are different.
Willcox
I know this has to be tough to do...because the new sender I bought due to the thread size in the cylinder head was different (smaller)...that when I installed it...the sender worked but was about 100 degrees off.
DUB
I've tested the last proto.. and the boards are here now.. Honest truth, we don't have time to build them just yet. The other major vendors are killing us for the other parts... (tach boards, Low fuel warning modules, delay timers, and other electrical stuff) We're building them as fast as humanly possible right now. I will not send these parts oversea's.. We should be ready to finish them up in a week or so.
I'll let you in on something else.. I too was told a certain brand of senders had the oil in them... they don't. I cut three different senders apart to see... none had oil in them.
The oil isn't really the issue anyway.. The issue is the thermister inside the sender being wrong. The oil in the senders serves two purposes.... 1) It allows for a constant heat up of the sender dispersing the heat through the entire cavity.
2) It keeps the sender spring from corroding where it meets the top button contact.
That oil should you cut one open... is more than likely pyranol which contains pcb's... not something to play around with either..
In the thread you'll actually see a picture of a corroded spring that caused a failure in the sender. So what happens.. over time the oil leaks out of the sender. When it gets below the spring to top contact point it will corrode and when this happens the sender fails. http://forums.corvetteforum.com/c3-g...-you-dare.html
But... there is a new brand of senders that have recently hit the market.. I have all of them on order and they should arrive soon.. I'll be boil testing these, charting them and yes... cutting the tops out to inspect when they arrive. I'll probably video this when I do it.
Willcox
Willcox
It seems to me that each time I have to buy a part I shutter in fear that some DUMBA$$ "bean counter" had to get their hands in how "stuff" needs to be made so they can make more money selling crap.
I AM NOT WRITING THAT YOU are the mentioned above "bean counter"..AT ALL.
Best of success in your conquest.
DUB
So I installed the new gauge, leaving out the 90 ohm resistor as per the included directions, and the gauge reads the same as the old one, right around 150 degrees. Does this mean that my problem lies with the sending unit?? I'm confused here seeing that both the 72-74 gauge and the 75-76 show the same temp with the same sender. Were they not supposed to have different senders?
Willcox, do the senders from lectric limited work and make the gauges read right?
I have a Wells TU5 sender and it works properly on my 74, what sender do you have?
