Holley 4160 help....
The "off idle circuit" on one side, doesn't work. It idles fine mostly, but as soon as you crack the throttle w/a load, it drops 4 cylinders and turns into a V4; it only runs on the 4 cylinders fed by one plane of the dual plane intake.
While it's doing this, if you manually manipulate the accelerator pump, the 4 dead cylinders jump to life -proof that they're starving for fuel just off idle. Open the throttle more, and as soon as the main circuit comes on line, it runs normally.
This started a couple years ago, and I took the carb apart, cleaned/shot air/shot brake cleaner through all the orifices in the metering block, and put it back together...same problem. Took it in to work (shop) and several mechanics played w/it, poking wire through orifices, etc, and after that, it ran much better, for one summer. Now...it's back to the same thing. Took it apart tonight, and I'm telling you...the thing is CLEAN inside. No residue, no varnish, it's clean. I started blowing though every orifice again, paying close attention to the ones that feed air and fuel to the idle and off idle ports. Found no restrictions or debris.
Any ideas?
One other thing that is odd to me, is that in the throttle body, there are two holes, forward of the primary bores. One has a TINY orifice in it that connects to the left side idle circuit. I can fit one strand of a coper wire through it, barely. The other side is blocked off. I can't get shop air or a wire through it. Thing is, when mounted on the engine both those ports are covered/blocked off by the base gasket. Any thoughts on these?
http://forums.corvetteforum.com/c3-t...or-review.html
Wish I could be of more help sounds like youve narrowed the problem down now just figuring out how to tackle it.
Put it together this am, fired it up, no diff. I DON'T "GET IT". How can passageways that move air and fuel, stop working or "wear out"?? Grrr. Apparently, metering blocks for '06 and earlier 4160's have been discontinued too, which is BS. I'm pissed. I don't like Holleys, I don't "get" why in the world this thing won't deliver fuel off idle, I don't like Edelbrock carbs either so what do I do now? I want to understand why this thing won't work.
The initial good news is that you know the carb was working correctly at one point. Then you have determined that one half of the primary circuit cuts out during the transition from idle to cruise. That is great troubleshooting sir.
The part about the discontinued metering blocks is interesting. What about the aftermarket ones like Quickfuel?
I had been thinking about one of these for a while but haven't done so.
http://www.summitracing.com/parts/qft-34-8/overview/
You may also check craigslist if there is a listing in your area for 4160 parts. You may be able to pick up a parts carb for $10-$15. Swapping in another metering block would test your hypothesis. Seems like the odds of the same circuit on the same side of a different block failing would be slim. It would at least give you a second set of parts to dabble with.
Good luck, keep us posted.
As for gaskets, I'm using "Holley" gaskets, but the problem started w/no changing of any gaskets, in the first place.
As a last resort I would try sticking a proper sized wire from an acetylene torch tip cleaner into the suspect passageway. They are not smooth or soft like a copper wire.
I second the ethanol messing things up.... fuel stabilizer helps. I pulled my edelbrock Carb off my vette last spring and it looked like it was filled with clear jelly. Same issue with my motorcycle .
I had dual dellarto carbs on a VW kit car that drove me nuts till I found two plugged passages I could not free up...ended up buying another set of "parts carbs" and swapping everything to them which resolved my issues. The ethanol also effects the rubber fuel lines I've been told.
Ran smooth as glass.
Great fix!
Pete
Unfortunately, I spoke too soon. Ran absolutely flawlessly for about two hours....then went right back to doing the same BFS that it was before; hard staring, rough idle, wants to stall, and no off idle circuit feed at all. Odd thing is, if I run it under a good load for "a while" (5+ minutes?) then it idles smooth again, and comes up off idle OK. Shut it off and restart though, and forget it. Garbage.
Unfortunately, I spoke too soon. Ran absolutely flawlessly for about two hours....then went right back to doing the same BFS that it was before; hard staring, rough idle, wants to stall, and no off idle circuit feed at all. Odd thing is, if I run it under a good load for "a while" (5+ minutes?) then it idles smooth again, and comes up off idle OK. Shut if off and restart though, and forget it. Garbage.
Yes, good observation. I got the blue gaskets. Going to try the Harbor freight, ultrasonic parts cleaner w/carb cleaner next.
As an example, Holley sells the Street Avenger series and we installed a 670 cfm on a client's classic Chevy short and wide, pickup at the shop, that had a terrible carb, that the customer picked (drag racing carb!) . The Street Avenger ran flawlessly out of the box! The misbehaving truck, that surged, with a rough idle and misbehaved in general, was suddenly a sweet, but potent little truck. The carbs are individually flow tested, wet at Holley and are very easy to deal with. Even the vacuum secondary springs, are right there at the top and it takes less than two minutes to even change one out. Smooth idle and very crisp response.
Of course, this is just a suggestion, if you want to continue, you might just defeat it. Just might...
I have <5 hours in it so far. Probably about 3.
What about something like trimmer line, it's flexible, just may not be small enough? Or large fishing line?
100%. The problem is, those passages make abrupt changes in direction (drilled from different angles). so you push something in there, not knowing which way a passage turns or jogs, and the "poking device" stops. There are tiny "freeze" plugs pressed into the top of the metering block -obviously plugging a drilled passage. /i may try to remove those so that I can actually SEE down into the passages in the metering block. Can't hurt at this point...I figure the metering block is junk at this point.
