Depending on the lifter brand, I've seen them pump up enough at higher rpm to hold a valve open if they are right on the edge of being adjusted too tight. If everything else checks out ok, you might check this as a last resort.
It sounded like the right side, I have comp cams cam, lifters, springs, rockers and pushrods. I just checked the right side valves and they are good to go. I took a little advance out of it and will run it tomorrow and then check the left side springs. This has a brand new Holley on it and I never paid it any attention but it doesn't have the plugs to check the float height. I am going to change to another set of float bowls tomorrow too just in case the back side is to low
What the heck kind of Holley is that? Street Avengers even have a plug.
