Guys I have a question, my car runs good idles good but when I get down on it will backfire out the exhaust when the carb goes on the back 2 barrels. It`s a 383 with a 600 holley and edelbrock manifold. I a thinking it`s to lean on the back side of the carb. I replaced the points with a Pertronix 3 and the rev limit is set at max and my timing is dead on the money. Just cruising around it is no problem but when I wind it up and go through the gears it will backfire. Any suggestions?
Seems like you need to pull the rear float bowl and see if there is something blocking the fuel flow, have a look at the metering block as well and make sure the jets and passages are clear. From your description it sure seems like your getting lots of air flowing but not enough fuel.
Popping out the exhaust at higher rpm is usually too much ignition advance. You can easily test this by running the engine in neutral up the rpm range. If it exhibits the popping in an unloaded state, take some advance out of it.
Unless you have done something to the carburetor, I doubt you find this to be a fueling issue.
The carb is a brand new 600 Holley, as for timing I have 32 total at 3000 and 12 at idle with stock springs. It won`t pop unloaded I can take it to 5 or 6 and it sounds great it only pops under load.
New plugs, wires and boots. This is a brand new engine I just built I am going to swap out my old Edelbrock performer carb and see if that gets rid of it but I don`t like it because the fuel in the bowl gets so darn hot even with an insulator plate it boils in the bowl and the Holley is a different design and the fuel doesn`t get so hot.
Hope it's this easy.
Are you saying that you can accelerate with no problem but when you let up on the gas you hear it after fire in the exhaust?
If so adjust your idle mixture screws.
Had that problem with a69 quite a few years ago. Turned out to be the coil breaking down.Only did it when rpms were up.Would run fine at idle up too about 2000 rpm
it accelerates fine up to about 4k then it pops out of the exhaust under load
now that could be it I used the old stock coil, I am checking the float height and metering block in a few minutes
