Borgeson Leaking
Ive been back on the road for a month or 2 now since reinstalling the Borgeson, and all seemed ok as far as I could tell. Today I was doing a little looking around, and noticed that the Borgeson, the surrounding frame, the pitman arm are all damp with oil again. They were completely spotless when I reassembled the car back in December. I painted the frame where the crack was, which happens to be in the area where the Borgeson mounts to the frame, and since the area was clean, I painted the entire frame where the work was being done.
I could swear its coming from where the top silver plate meets the box. See the pic. The oil seems to be pooling in the cavity in that plate. It also seems to be dripping down the box, onto the frame, and onto the pitman arm, etc.
If I take the Borgeson off the car again, its not going back on. After going through all of the hassle installing it the first time, then having to remove it and pay a bunch of money to ship it back to Borgeson just to have them tell me its fine, then reinstall it again, now back to leaky square one. This is getting old. Im starting to hate this car.
Someone suggested it might be brake fluid leaking onto the Borgeson, and although I cant completely rule that out, I did consider it. When I was searching around tonight there are no clear signs of that happening. The master cylinder is not damp like everything else below it, and there are hoses and wires between the master cylinder and Borgeson that done appear to be wet at all.
Especially after getting it back.
Those frame issues aee worrisome.
Thw welds are messy. You might want to grind that area clean, re weld and rustproof. Maybe reinforce wirh a plate.
This may sound silly, but did you overfill the pump? Very easy to do, I know. It is under the alternator and hard to get to.
If it is overfull, fluid will blow out of the top until it reaches normal level.
I decided to tear the borgeson out of the car and return it for repair. Took the better part of the day to get it out, and had to remove the steering column...again...and get that freaking pitman arm off. What a pain.
Shipped it back to borgeson..and UPS lost it.
But 2 or 3 days later it showed up at Borgeson.
Now for the disappointing part.
They hooked it to the testing equipment and said they couldnt find anything wrong. They said they tested it under a heavy pressure load, left it under pressure for a while, but found no leaks. I explained as much detail as I could, but they said there is no other testing they can perform that they havent already done, and that was their conclusion.
REALLY frustrated with this. So now its on the way back to me...just the way I removed it, so I can spend another day installing it, and praying it doesnt leak again.
REALLY bummed about this. The pics clearly show it leaking from 2 different places, none of which is the hose connections, and spending all of that time installing, removing, and now reinstalling again, anticipating that this is going to need to come out one more time....its making me crazy. That is a lot of time, money and frustration waisted. If I have to tear it out again, Ill just switch back to the factory setup.
The frame was welded and reinforced, cleaned, painted. Im not 100% sure that it resolved forever, but it was a better alternative than junking the car or replacing the frame. I will be watching it carefully, thats for sure.
Im sure the pump was not overfilled. If it were overfilled, i would think the fluid wouldn't likely end up on the Borg box and pitman arm. It would be on the pump, crossmember and surrounding area i would think.
Maybe I will start thinking about R&P.
Hope you can resolve it.
65-StingRay
I feel for your frustration with this. Here are a few things to think of that may find the culprit. I notice that the return line in the first photo runs right over the top of the box, could there be a minuscule hole in the hose? If not the return line, then maybe the high pressure line has a pinprick that is allowing fluid to leak onto the frame and then down into the side cover (that's what they call the "top" cover). Then there is the adjusting screw in the middle of the side cover, could this be the source of the leak?
I agree with the others who commented on the "welding" on the frame, Bubba was having a good day there! The flexing frame would cause the box to move sideways, putting intense strain on the seal at the input shaft, possibly causing a leak.
Either of the above paragraphs could be the source of the leak, which would explain why Borgeson could not find a fault with your box. They did not have your hoses or chassis and steering shaft to connect to your box when they were testing it.
A white paper towel or shop rag wrapped around the hoses and secured with tape would soon show if the leak was coming from the hose/s.
Good luck with finding the cause of your leak.
Regards from Down Under.
aussiejohn
65-StingRay
Fingers crossed its not the box.
aussiejohn
Thanks for the post. That is a great point about the hoses that I will investigate.
As mentioned, Bubba's handiwork has all been repaired. In addition to the newly repaired frame and cleanup of all the fancy welds, a spreader bar was added, so frame flex has been greatly reduced. There is no abnormal pressure on the box now.
Thanks for the great suggestions. I will try the paper towel trick tomorrow.
Did you use the brass sleeves?
Those high pressure hoses need a LOT of torque to keep them from leaking.
I had to really crank on mine to seal them up.
regards Ian
aussiejohn
